2012-03-27, 21:03
Hey,
well, my target release was planned for 2012-06-01 but.. times have changed
Here is the new LPC 1.3.0.
Please uninstall older versions of this software before installing a new version.
Change log:
New features:
(see full list of tickets for 1.3.0)
I included a short README.pdf in the installation directory.
Cheers & Leg Godt
Nils
Change log:
New features:
- You can activate the overlap/T-junction detector by clicking on “Edit->Detect Triangle Overlaps”
- The application is translated into three different languages (English, French, German)
- You can create 1 or 2 triangles by selecting 3 or 4 vertices when “Add Triangle” is activated
- Colours can be replaced after the Rectifier-post-process (click on “File->Replace Colours on Export..”)
- You can set the center of a group/subfile
- You can configure the zoom level (click on “View->Zoom” or double click the zoom label [“Zoom: … %”])
- You can manipulate the transformation matrix of primitives/groups
- You can select overlapping/covered triangles with two or more mouse clicks while pressing the CTRL key
- You can “cut” the polygon of a template with the CUT keyword in the template definition file
- You can deselect a selected vertex/triangle when you click on it while holding the CTRL key
- You can move/rotate/scale selected things, one tick at a time, using keyboard up/down/right left.
- The rotate mode is improved.
- The colour palette is now resizable
- The projection data import and the projected export is now ready for use
Cheers & Leg Godt
Nils
