Looking for challenging modelling opportunities such as this
big wheel. It would help if it is something from a set I might have or get (Technic/Star Wars), or the LDD mesh is reasonably close.
In the interim If no objections and interest in the parts, I'd like to add the Heroica Die Tiles, and weapons to my personal work queue.
3068bpb417
3068bpb418
3068bpb419
3068bpb420
94158*
Hey Greg,
the 94158e and 94158d are available in the LDD; so maybe no challenge?
94158e should be 95050 - MOON STICK.
94158d should be 95049 - SUN STICK.
Rolf
there is some parts sitting on the PT with "hold" votes currently,
they all need our help getting fixed...
hmmm, heads & helmets, hmmmm.
tried the clone trooper helmet & Kit Fisto (my favorite Jedi).
should probably get my dxf converter going again to tackle those. would be good incentive to do more coding.
also would be good reason to take a second look at the 3d-scanner now that I have an NXT
thanks for the info Rolf. would be good to know if the others have real numbers
that these are in LDD is good, I might have a starting point for the grip which is an obvious subpart for the set.
looking now - glanced at some of the 'Needs Work' last night.
noticed a lot of interiors missing for multi-piece parts that I don't have >_<. I could make something up o_O.
I'll look for the old held stuff. All of mine are sub-parts that got in-lined
Just in case you didn't know it yet: here's the PT tools page
http://www.ldraw.org/library/tracker/tools/
When you click on "file queue", you can see the "oldest" parts
(in terms of when an action happened there last).
Those are probably the ones waiting the longest.
However, I'm not using that tool very frequently. Instead, my workflow is like this:
I look at
http://www.ldraw.org/cgi-bin/ptlist.cgi
and first look at parts which need a second vote to get ready for Admin review.
Then I look for parts which not even got their first vote.
And from time to time, I scroll to the very bottom of that page and run through
some held files listed there, seeing what I can do to help,
as I think there is no use in files being held for years. Instead, the problems
need to get fixed. (There's somewhere a rule saying that if a file is held for some
time, everybody is invited to help solve the problems.
Just be careful to not step on someone's toes.)
In the
Parts Tracker Policies it is stated that ater 3 months of no action, anyone is able to take over the development.
even your clikits elements
