2012-03-02, 20:30
2012-03-03, 8:27
Would someone have good photos of this one (especially from side?)
2012-03-03, 15:48
please take a look at
http://c-force.org/ldraw/x99_side.jpg
http://c-force.org/ldraw/x99_bottom.jpg
maybe that helps?
maybe that helps?
2012-03-03, 15:57
Christian Neumann Wrote:maybe that helps?Thanks, should be enough to do the part!
For more precision...
- depth of cavity?
- diameter of string hole?
2012-03-03, 16:11
ups.
cavity is 5.25 LDU, stringhole seems 3.75 LDU (difficult to measure, possibly 4 LDU).
2012-03-04, 12:47
Christian,
I have some coherency problems between the measurements you added and the overal shape on the photos. Mainly the overall length seems a bit longer than 80ldu (or the hook is narrower than 24ldu). Could you confirm the length before I flesh out the hook? Attached the part so far, with just the outline of the hook, total length=84ldu.
2012-03-04, 14:19
Philippe \Philo\" Hurbain Wrote:the overall length seems a bit longer than 80ldu (or the hook is narrower than 24ldu
Philo, you're right. The overall length is 82.75ldu, and the hight of the hook element is 22.75ldu instead of 24. That happens when measuring against another brick, and not with a caliper :-(
I'm really sorry about that!
2012-03-06, 19:23
