2012-02-19, 18:27
The current convention for titling Physical Colour files is to append the colour name to base part's description. However, I have not been very consistent in enforcing one colour naming dialect, some of which have changed over time. Also the length limitation often requires some contraction of the base part description or the colour name which adds to the confusion:
Would it help to define some syntax to show the colour code, which would at most require six characters e.g.
or codify the colour some other way within the header syntax?
9359 = "_Brick 1 x 6 w/out Centre Studs with "TAXI" Pat. Trans Green"
3067p11 = "Brick 1 x 6 w/out Centre Studs w/ White Sans-serif "TAXI" Pat."
4211814 = "_Hinge Plate 1 x 2 Locking with 1 Finger On Side Vertical [71]"
