2012-01-10, 11:33
2012-01-10, 11:38
Assembled by SR3D Builder 0.6.0.9 + MLCAD 3.3
Rendered by Mega-Pov 1.2.1
First and Second Model - Complete
Enjoy
2012-01-10, 11:43
First model is incomplete (without 99009 Technic Turntable Small Top and 99010 Technic Turntable Small Base)
Enjoy
2012-01-10, 11:46
Complete except stickers.
Enjoy
2012-01-10, 11:50
Enjoy
2012-01-10, 11:56
Enjoy
2012-01-10, 12:43
Excellent!
2012-01-20, 17:00
Wonderful pictures! My only concern is that there are no MPD files to download .
2012-01-20, 18:56
L3B is the file extension that SR 3D Builder uses when it saves LDraw files. They aren't MPDs, but they do appear to be standard LDraw files. All of these have L3B attachments, and if you open them in your favorite LDraw editor/viewer, they should load fine.
2012-03-16, 0:08
Assembled by SR3D Builder 0.6.3.7 + MLCAD 3.3
Enjoy
p.s.
9397 Logging Truck(Main model) needs below parts to be complete.
- 99009 Technic Turntable Small Top
- 99010 Technic Turntable Small Base
2012-05-23, 8:59
Here is the Motorized Bulldozer (8275) of 2007
build with MLCad 3.3
all angles are calculated with help of Autocad and SolidWorks
I used 43 instead of 42 chain-links, cause all calculations I made, had given the result that I need 42 and a half chain-link.
The model is not OMR compliant - sorry. It takes me too much time to think for a name for every sub-part.
Rendering was done with POV 3.7 RC3
Electric wire was generated with LSynth. I have not yet included these files. (the PF Wire constraint and the PF Wire "part")
Regards
Max
Regards
Max
2012-05-23, 9:13
Combine Harvester (8274)
Regards
Max
Regards
Max
2012-05-23, 9:23
Dragster (8274 B-Model)
Regards
Max
Regards
Max
2012-05-23, 9:28
Off Road Truck (8273)
Wire was generated with LSynth. I have not yet included these files. (the constraints and the Wire "part")
Regards
Max
Regards
Max
2012-05-23, 9:31
Utility Cargo Truck (8273 B-Model)
Regards
Max
Regards
Max
2012-05-23, 9:34
Snowmobile (8272)
Regards
Max
Regards
Max
2012-05-23, 9:36
Bulldozer (8272 B-Model)
Regards
Max
Regards
Max
2012-05-23, 9:41
Crane Truck (8258)
Wire and electric wire were generated with LSynth. I have not yet included these files. (the constraints and the Wire "part")
Regards
Max
Regards
Max
2012-05-23, 20:27
Max Martin Richter Wrote:The model is not OMR compliant - sorry. It takes me too much time to think for a name for every sub-part.
Max,
I perfectly know what you're talking about since I'm currently make your 10185 - Green Grocer OMR compliant. I really beg you to standardize those fantastic models. I CANNOT make all the models posted here fit for the AIOI myself - it's a matter of time also on my side.
2012-05-24, 8:13
Hej Willi,
I think, you're right. So let's see, what the future brings.
The next weeks I will be very busy with my studies, but afterwards...
Max
Max
2012-08-19, 15:56
I've just ordered this set today and just found your topic : you've done a great modelization, thanks for sharing it.
2013-06-08, 13:29
I 've done to assemble 42000 Grand Prix Racer.
This model is complete, except sticker and 9L link connection mismatch slightly in front wheel.
Click the picture to expand it and see in the red circle.
You can use this file as you want, without any permission from me (copyright free), if you didn't intend to use it for commercial.
You might need to find some new unofficial parts at http://www.ldraw.org/library/tracker/.
Great Thanks to Mr. Philippe Hurbain for making new parts
2013-06-08, 14:33
Quote:This model is complete, except sticker and 9L link connection in front wheel. (see the below picture)Why? It is not a new steering link type, is it?
Quote:Great Thanks to Mr. Philippe Hurbain for making new partsYou're welcome
2013-06-28, 10:19
Hi
This is new technic model 42006 Excavator.
There are some connection-mismatch slightly, but looks good.
You can use this file for your own every purpose, except commercial use.
Enjoy
KWON
2013-07-03, 1:02
This is a new technic model of this year.
You can use this file as you want, except commercial use.
Enjoy
KWON
2013-07-04, 4:31
This is one of my favorite model.
Enjoy
KWON
2013-07-04, 6:54
Quote:This is one of my favorite model.B-model is not bad either
2013-07-09, 13:56
This is B-model of 9396 and very interesting one with twin main rotor.
If you have SR3D Builder, you can see the animation of twin rotor movement.
But I am sorry that landing gear movement is not correct yet.
There are some connection mismatches due to assembling tolerance in real world,
but I try to hide it invisibly. ;P
Enjoy
KWON
2014-09-08, 16:41
KWON, you have not posted in a long time. Are you still actively making Technic models in SR3D? I am looking for some models of current Technic sets for Technicopedia.
2014-09-12, 9:15
[attachment=1340]
Done with SR3Dbuilder + LSynth + MLCad.
MPD built with MPDCenter (thanks for the help, Mike!). Should be OMR compatible.
Known errors: Missing stickers, Technic figure torso has no pattern and has a plain left arm instead of a biomecanical one.
2014-10-11, 4:22
Added to the AIOI. Thanks for sharing!
2018-10-19, 15:41
(2012-01-20, 18:56)Travis Cobbs Wrote: [ -> ]L3B is the file extension that SR 3D Builder uses when it saves LDraw files. They aren't MPDs, but they do appear to be standard LDraw files. All of these have L3B attachments, and if you open them in your favorite LDraw editor/viewer, they should load fine.
Hi, all:
Is there any one who keeping using SR 3D Builder? Do you have SR3DBuilderDBG.EXE?
I can not get this file anymore!
2018-10-19, 18:09
(2018-10-19, 15:41)Shih-I Yang Wrote: [ -> ]Hi, all:I used SR3D, but now I've switched to LDCad and I don't regret the move! the only thing that I sometimes miss is the animation possibility (that worked automatically from mechanical assembly). LDCad allows animations (and they work great) but you have to write scripts.
2018-10-20, 9:51
(2018-10-19, 18:09)Philippe Hurbain Wrote: [ -> ](2018-10-19, 15:41)Shih-I Yang Wrote: [ -> ]Hi, all:I used SR3D, but now I've switched to LDCad and I don't regret the move! the only thing that I sometimes miss is the animation possibility (that worked automatically from mechanical assembly). LDCad allows animations (and they work great) but you have to write scripts.
Yes, you are right. SR3D is good in animation support, that's why I use it to demo kinematics of building structure. It is quick and simple.
I saw SR3DBuilderDBG.EXE is used for maintenance mode in http://jc-tchang.philohome.com/model/SR_3D_Builder.htm.
But the download link is not valid. Do you know where else I can get the backup?
