Full Version: LDraw.org 2026-09 Parts Update Now Available
The 2026-09 LDraw Parts Update has been released. This update adds 161 new files to the core library, including 121 new parts and 9 new primitives. As of this update, the LDraw.org Parts Library contains 17164 unique shapes or patterned parts.
Thanks are due to all the part authors who created or corrected parts for this release. The small, but dedicated, band of reviewers also play an important role in keeping files moving through the Parts Tracker and deserve just as much credit. This update wouldn't have been possible without their dedication and attention to detail.
You can preview the new parts in 2026-09 here, and download the update here.
Thank you to all the testers and parts authors who continue giving feedback on the PT software. This project would not be what it is without your help.
Note: The Windows installer will be delayed. I will post an update to this thread when it is available.
Orion Pobursky
Magnus Forsberg
Gerald Lasser
LDraw.org Parts Library Admins
Due to limitations on my end, I am unable to make the Windows installer with my current computer. Unless I have time to figure out a workaround, this will be the case for the 2026-10 and 2026-11 updates as well.
(2026-10-09, 20:43)Orion Pobursky Wrote: [ -> ]Due to limitations on my end, I am unable to make the Windows installer with my current computer. Unless I have time to figure out a workaround, this will be the case for the 2026-10 and 2026-11 updates as well.
Would it be at all possible for one of the other administrators to create the Windows installer?
(2026-10-12, 4:05)Mark Kennedy Wrote: [ -> ]Would it be at all possible for one of the other administrators to create the Windows installer?
I'm on an extended work trip and, due to an oversight on my part, the file used to generate the setup is back home.
That said, I just found an outdated copy of that file in my cloud drive and I'm pretty sure I can update it to work.
And, it works!
The windows installer is now available.
Note: I generated this via a Docker image on Ubuntu Linux. I had one of the team test it and it seems to run fine but if you encounter any quirks, please post them here.
