Full Version: (unofficial) Part 7684 - broken in both LDView and MLCad
It looks fine on the LDraw website, but when I update my Unofficial parts library, it appears broken in both LDView and MLCad.  I have tried this on multiple Windows 11 amd64) devices.
Screenshot of part 7684 in both apps:
[Image: part_7684.png]
This is not a new issue, I probably noticed it 6 months ago, but was busy and didn't want to file a bug until I had repro'd the issue on a second PC.
---Tom
P.S. It is a new part for 2026, and since it is already in 3 sets and 3 different colors, it is ranked in 1029th place for the year.
What, if anything, does the LDView error window show.
It looks like you don't have the correct version of the needed subfile s\64451s01.dat
It has been reworked and is now used in three parts: 64451, 11455, and in the new 7684.
[attachment=14248]
(2026-08-04, 7:18)Magnus Forsberg Wrote: [ -> ]It looks like you don't have the correct version of the needed subfile s\64451s01.dat
That is likely the problem, but I do not know why I would be in this situation.
Why wouldn't I get that file automatically if I take the following install steps on a brand new PC:
  1. Install x64 LDraw AIOI - LDraw_All-In-One-Installer_2026-01_setup_64Bit_v1
  2. Install x32 LDraw AIOI - LDraw_Additional-Tools-Installer_2026-01_setup_32bit_v1
  3. Launch LDView, File > Check for Library Updates
  4. Download latest Unofficial parts from: https://library.ldraw.org/library/unoffi...rawunf.zip and unzip them to C:\Users\Public\Documents\LDraw\Unofficial
  5. Launch MLCad, File > Scan Parts
That's a detailed explanation of my install routine on a new PC.
It's likely there is a problem in some step like "Check for Library Updates". If this were buggy, maybe it needs to be fixed at an installer or app level. It is also possible that, for some reason, those subparts aren't getting included in the Unofficial Parts .zip file.
Sincerely,
---Tom
P.S. if this isn't a part issue, we can move thread to a different forum.
(2026-08-04, 19:03)tom alphin Wrote: [ -> ]It's likely there is a problem in some step like "Check for Library Updates". If this were buggy, maybe it needs to be fixed at an installer or app level.  It is also possible that, for some reason, those subparts aren't getting included in the Unofficial Parts .zip file.
Try downloading the complete.zip from the latest update and replacing your LDraw directory with it's contents.  If that works then LDView isn't downloading updates as it should (which may be a problem with the LDraw server, LDView, or both).
As the sub-part is an official part (but reworked) LDView is lacking this information.
The part in question and the common sub-part are still unoffical
LDView finds the old sub-part and uses it. It won't update.
  1. I confirmed that my C:\Users\Public\Documents\LDraw\ folder matched the contents of complete.zip - and it matches exactly.
  2. The next thing I confirmed is that the latest version of 64451s01.dat is in the C:\Users\Public\Documents\LDraw\Unofficial\Parts\s folder - It was correct and up to date.
  3. Next, I manually overrode the version in C:\Users\Public\Documents\LDraw\parts\s to the newer version from the Unofficial folder, but it still did not work correctly.
  4. Finally, I went into MLCad > file > Scan Parts, then added the part to the project file again - and it finally worked as expected in both MLCad and when exported from LDView.
Problem Statement:
LDView and MLCad do not (seem to) use the newer 'p' files from the Unofficial subfolder if that file exists in the official repository.
Potential Fixes:
  1. Modify LDView and MLCad to use the unofficial subparts when they are newer than the official subpart.  (Likely not possible since MLCad is not being updated)
  2. Reference a unique filename when a subpart needs to be modified to support an unofficial part.  ex: 64451s01_unoffical.dat  - This is likely a rare workaround. When part is brought into the official repo, the unofficial reference is removed when the subpart has been updated.
Thanks all,
---Tom
(2026-08-05, 3:38)tom alphin Wrote: [ -> ]Problem Statement:
Don't you mean the 's' files?
Somewhere a choice must be made: Should one or the other version of a file with the same name be used?
How does LdView handle that question?
I know from experince that MLCad doesn't handle it correctly. That's one of the reasons I stopped using it.
(2026-08-05, 6:13)Magnus Forsberg Wrote: [ -> ]Don't you mean the 's' files?
Yes, I misspoke - I meant the 's' files.
LDView also handles it incorrectly - see previous photo. It uses the official one, even if a newer s/ file exists in the unofficial folder.
This is why I proposed a workaround, adding a postfix for the unofficial file, until it is merged into main.
(2026-08-05, 13:39)tom alphin Wrote: [ -> ]LDView also handles it incorrectly - see previous photo. It uses the official one, even if a newer s/ file exists in the unofficial folder.
The current LDView behavior is by design, and this case obviously wasn't considered. I'm not sure if I'll try to fix it or not, because fixing it would likely introduce new problems. I believe that you can fix it locally by creating an ldraw.ini file that searches for unofficial parts and primitives before searching for official ones. It should look something like this:
[LDraw]
BaseDirectory=C:\Lars\LDraw
[LDrawSearch]
1=<MODELDIR>
2=<UNOFFIC><HIDE><DEFPRIM><LDRAWDIR>\Unofficial\P
3=<UNOFFIC><DEFPART><LDRAWDIR>\Unofficial\PARTS
4=<HIDE><DEFPRIM><LDRAWDIR>\P
5=<DEFPART><LDRAWDIR>\PARTS
6=<LDRAWDIR>\MODELS
Note: The entire [LDraw] section may be optional, but if it's not, BaseDirectory needs to point to your LDraw directory.
I think that the above will only work if you don't have LDView configured to use an LDraw parts zip. Store the above text in a file named ldraw.ini in your LDraw directory.
Alternatively, the file can go in other platform-specific locations:
Windows: You can put the path to the file in an environment variable named LDRAWINI, or you can put the file in your USERPROFILE directory (typically C:\Users\<username>).
Non-Windows: Put the file in ~/.ldrawrc, ~/ldraw.ini.
I've solved it by constantly remove any official file that get a reworked version uploaded to the PT.
But I'm also a very active part author.
Another solution is to dump all unofficial files in the "official" file structure.
(2026-08-05, 16:17)Travis Cobbs Wrote: [ -> ]The current LDView behavior is by design, and this case obviously wasn't considered. I'm not sure if I'll try to fix it or not, because fixing it would likely introduce new problems. I believe that you can fix it locally by creating an ldraw.ini file that searches for unofficial parts and primitives before searching for official ones. It should look something like...
Travis, this is useful information, thanks for sharing.
I guess that I am still not sure why a process level workaround (like the "_unofficial" filename) wouldn't make sense in the rare case where a subpart in the "s/" folder needs to be modified to support a new part without breaking backwards compatibility with an existing part.  This would be easy to manage with a git-style fork containing only the updated subpart and the small number of parts impacted by the change, but I do not think LDraw Parts Repo has branching capabilities.
The biggest point of confusion comes from the disconnect between what is shown on the website and what is shown in LDraw.
  • Whatever script generates the preview image shown on the website uses the unofficial subparts (ex: https://library.ldraw.org/parts/50658 )
  • The same part appears broken in LDView and MLCad, likely other apps as well.
---Tom
(2026-08-05, 17:54)tom alphin Wrote: [ -> ]" in the rare case where a subpart in the "s/" folder needs to be modified ..."
I find it odd that you only have 1 part showing issues. We currently have ~400 sub-parts/files recycled on the PT.
As I see it, any recycled part will not be prestented correctly untill it is back in a new release.
(2026-08-05, 18:19)Magnus Forsberg Wrote: [ -> ]I find it odd that you only have 1 part showing issues. We currently have ~400 sub-parts/files recycled on the PT.
As I see it, any recycled part will not be presented correctly until it is back in a new release.
🤷‍♂️ I'm honestly not sure why...
I suspect most of the subpart changes are subtle, and I simply have not noticed them for my use case - exporting part images from a single angled perspective for use in my labels and part guide.  It's important to my readers / users that I include brand new parts - which is why I need to use unofficial parts because it can take a long time for final parts to be approved.
s\64451s01.dat was significantly refactored as you noted yesterday. The image you provided clearly illustrated the significant change to the subpart design.  This made the changed subpart very visible.
(2026-08-05, 17:54)tom alphin Wrote: [ -> ]This would be easy to manage with a git-style fork containing only the updated subpart and the small number of parts impacted by the change, but I do not think LDraw Parts Repo has branching capabilities.
We don't use any type of VCS for the library (yet).
I have several server modernization projects going at the moment and once those are stable, I'll pivot to moving the library to git.
(2026-08-05, 17:54)tom alphin Wrote: [ -> ]Travis, this is useful information, thanks for sharing.
---Tom
The current LDView behavior is obviously causing a problem, but simply updating it to prefer unofficial files over official ones isn't a working solution. Each time the library is released, the unofficial files in that release that are no longer unofficial disappear from the unofficial parts list on the ldraw.org server, but LDView doesn't really have any way to be aware of this. So, if you have an unofficial file which is updated right before the release, LDView will never notice the update. But since it will then pull the file from the official list instead, this doesn't cause any problems. I'm not saying that this isn't something that can be fixed, but given how little time I spend on LDView, it's not something that I'm likely to work on.
I'm pretty sure that the web site's image generation happens with an LDraw library where all the unofficial files go alongside the official ones (overwriting them when there are updates to official files). TBH, if what you want is to ALWAYS show the latest unofficial files that you have downloaded, that's what you should do also, instead of storing things in the unofficial directory. (This was suggested above by Magnus.)
(2026-08-06, 22:45)Travis Cobbs Wrote: [ -> ]I'm pretty sure that the web site's image generation happens with an LDraw library where all the unofficial files go alongside the official ones (overwriting them when there are updates to official files). TBH, if what you want is to ALWAYS show the latest unofficial files that you have downloaded, that's what you should do also, instead of storing things in the unofficial directory. (This was suggested above by Magnus.)
It's actually a little more complicated. There is no "library" that LDView loads on the server. The library software creates a self contained MPD file of the part that has all the subparts/primitives included.  Since the library knows the subpart tree and if a part is official or unofficial it changes how that MPD is constructed. If the part is official, it only uses official data.  If the part is unofficial, it prioritizes unofficial files (e.g. part fixes) over official files.
None of this helps you Tom.
What I would suggest is use Travis's suggestion to prioritize unofficial over official parts and every on new LDraw release:
- Overwrite library with complete.zip
- Delete all your downloaded unofficial parts and either use the ldrawunf.zip or have LDView re-download the unofficial parts for you.
(2026-08-07, 2:16)Orion Pobursky Wrote: [ -> ]It's actually a little more complicated. There is no "library" that LDView loads on the server. The library software creates a self contained MPD file of the part that has all the subparts/primitives included.  Since the library knows the subpart tree and if a part is official or unofficial it changes how that MPD is constructed. If the part is official, it only uses official data.  If the part is unofficial, it prioritizes unofficial files (e.g. part fixes) over official files.
Thank Orion. This does actually match my current workflow, and it has been working well for years, since it is uncommon that an updated subpart is strictly required to render a decent part image.
What I find most interesting about your description of how the website generates part images is that it does pretty much what I suggested - prioritizing unofficial subparts over official subparts.  I think it is actually more nuanced than my suggestion, since only unofficial parts prefer unofficial subparts, and official parts prefer official subparts.
Unless each app can be updated to reflect this subpart inheritance logic, which is unlikely since some of the apps are basically abandonware, then we should probably live with the limitations until a branched source control system is implemented.
---tom
