Full Version: Current LEGO Colour Palette 2026 in LDraw
The amount of colours available for Lego pieces can be overwhelming at times, so I thought I'll post this image to give people a better overview on what is currently on the official Lego palette with the according LDraw IDs:
[attachment=14100]
Based mostly on https://www.flickr.com/photos/[email protected] with a few corrections/additions based on personal research.
I hope this helps:
  • Parts authors pick the correct colours for prints/stickers/dual-moulded parts
  • Model builders avoiding discontinued (hard to find) colours more easily
Some notes:
  • This is mostly speculative, not official. However most of it should be correct
  • "Pearlescent Metallic" refers to un-painted plastic with additives giving them a pearly-metallic look (do not use for prints!)
  • "Metallic Ink/Lacq" refers to a shiny paint coating on parts (but still more matte than chrome/vacuum-metallizing) or the ink used on prints/stickers. Both are considered the same by both Lego and LDraw
  • Some chrome elements (like the LotR One Ring) might still be active, but are usually no longer listed as active. Chrome is easily identified anyways, so I excluded those for now
  • "Glitter" is very transparent with big glittery flakes molded into the plastic; "Opalescent" is similar to Glitter, but the flakes are much smaller and have a much higher density, causing the base part to be more of a milky translucent rather than fully transparent. Rendering of these two effects varies heavily depending on program
  • I'm not that sure on status for the glitter/opal colours, but they seem to have been active within the last 3 years and felt it better to be inclusive here
  • Medium Blue (73) currently seems a bit "endangered" - only used in the Bluey theme in recent years
If you notice any errors/omissions let me know.
would it help for the colors if the columns would be sorted by "brightness"?
like keeping the "base" colors as center line and then arrange the lighter/darker variants above/below...
Open for suggestions regarding the order. It's mainly based on the official one linked (which is a bit random admittedly).
The browns/nougats look especially messy now.
However I also wanted to avoid creating too many rows with only 1 or 2 entries. Not all colour hues would have a corresponding entry for each lightness value (the 2000-2002 palette sort of had).
