Full Version: LDCad 1.7 Beta 2b (win+linux)
I've released LDCad 1.7 Beta 2b.
This version fixes three bugs:
- Part snapping not working when using an unpacked library.
- Potential crash during part editing combined with include meta's.
- Potential dead lock (program hangs) during mass file close.
It also includes the latest shadow library as found on github.
As always you can get the latest version at:
https://www.melkert.net/LDCad/download
Thanks Roland. I use LDCad daily and really appreciate your work on it.
In the new part bin I am missing some parts that were available in previous releases of LDCad:
Category Sorted | Technic | Connectors and Pins
- Technic Axle Pin (3749.dat)
- Technic Axle Pin with Friction with  2L Axle (17651.dat)
- Technic Axle Pin with Friction with  2L Pin (11214.dat)
- Technic Axle Pin without Friction with  2L Axle (65249.dat)
- Technic Axle Pin with Friction (43093.dat)
and some other parts with keyword "axle".
(2026-03-29, 11:16)Jens Brühl Wrote: [ -> ]In the new part bin I am missing some parts that were available in previous releases of LDCad:
Someone mailed me about this problem just a couple of days ago.
It seems my attempt to declutter has resulted in some unintended excludes.
I will address this in the next version, but you can also fix it yourself thanks to the new part bin filter group editor.
Like so:
While the 'connectors and pins' group is visible in the part bin open its menu and select 'edit'
This will open a dialogue that lets you edit the pbg.
In its rules section add ",axle pin" to the line starting with "keep" so it reads:
keep description axle towball,axle pin
Then click accept, this should readd your missing parts.
This fix worked for me. Thanks!
I cannot get LDCad to load after the first run on Ubuntu 26.04. First I had to install glu. The program starts, asks for the LDraw dir, and then loads the gui.  If you exit and then restart, nothing happens. On a lark, I deleted the config folder and the program behaves as it did for the first run (i.e. asks for LDraw dir) and loads the gui.
Log file attached.
P.S. All the links to the previous versions of 1.7 are broken. 1.6 doesn't work since it requires and outdated dependency.
(2026-10-04, 0:47)Orion Pobursky Wrote: [ -> ]If you exit and then restart, nothing happens. On a lark, I deleted the config folder and the program behaves as it did for the first run (i.e. asks for LDraw dir) and loads the gui.
So after the delete of config it did run?
The log shows nothing special.
Sometimes on Linux the OpenGL initialisation fails, but it would still show the gui just all black.
If you start the executable from a command line, it should show extra information.
Currently I compile the Linux versions on Debian 9 for maximum support, but it might be time to compile on something newer.
ps: the older links are disabled to limit traffic.
(2026-10-04, 18:42)Roland Melkert Wrote: [ -> ]So after the delete of config it did run?
- If I delete the config folder, the GUI starts (after the license and ldraw folder dialogs).  If I close and then reopen, the GUI doesn't start unless I delete the config folder again.
- I do run the program to the command line.  That's how I figured out I needed to install glu. However, there are no messages.
- Based on my experience with building LDView for the LDraw server, there are some differences between Debian and Ubuntu.
- I did some experimentaion.  The program does run normally if I run as root (e.g. sudo LDCad).
(2026-10-05, 1:06)Orion Pobursky Wrote: [ -> ]- If I delete the config folder, the GUI starts (after the license and ldraw folder dialogs).  If I close and then reopen, the GUI doesn't start unless I delete the config folder again.
Very weird. Bydefault (without a overiding ldcad.cfg) it will not write or read outside the binairy folder. So the root thing is very weird.
I will need to find the time to get a live version running of your Ubuntu version. Figure out what changed. I'm hoping later this week.
I do have exactly the same problem. start from command line: no messages, nothing special in the log.
If I start with sudo, messages appear:
(LDCad64:26572): dconf-WARNING **: 12:31:20.293: failed to commit changes to dconf: Failed to execute child process ?dbus-launch? (No such file or directory)
 But I don' know if this is relevant.
Maybe the problem has something to do with (not) showing up the licence-window with second start?
If I don't delete the config folder and start as root, the licence window is shown.
(2026-10-19, 10:38)Frank Engel Wrote: [ -> ]I do have exactly the same problem. start from command line: no messages, nothing special in the log.
I haven't had the time to do a deep dive into this problem.
But in a quick chat with AI it suggested you could try to install dbus-x11.
sudo apt install dbus-x11
I'm hoping to look deeper into the issue this weekend though.
(2026-10-19, 21:07)Roland Melkert Wrote: [ -> ]I haven't had the time to do a deep dive into this problem.
Nope.  That didn't work.
(2026-10-04, 0:47)Orion Pobursky Wrote: [ -> ]I cannot get LDCad to load after the first run on Ubuntu 26.04. First I had to install glu. The program starts, asks for the LDraw dir, and then loads the gui.  If you exit and then restart, nothing happens. On a lark, I deleted the config folder and the program behaves as it did for the first run (i.e. asks for LDraw dir) and loads the gui.
I've been trying to get the existing binary to work using some kind of workaround. But it seems only a sudo works.
The problem is wxWidgets related, 1.7 Beta 2b uses version 3.2.2.1 a recompile (on debian 9) using 3.2.12 seemingly fixed it.
I will prepare a new release later this week, I need to check my notes for some other pending tweaks/fixes to include in a 2c version.
(2026-11-03, 20:53)Roland Melkert Wrote: [ -> ]I've been trying to get the existing binary to work using some kind of workaround. But it seems only a sudo works.
Nice.  I appreciate you working this out. I recently switched to a Linux desktop on my travel computer and the experience has been so good that I might go full time at home as well.
I have a strong suggestion regarding ldcad's partbin: could you please add a partbin editing tool or function to facilitate visual editing? Editing plain text is simply too difficult and inconvenient; even a simple tool would be helpful.
(2026-11-16, 1:44)HWQ Wrote: [ -> ]I have a strong suggestion regarding ldcad's partbin: could you please add a partbin editing tool or function to facilitate visual editing? Editing plain text is simply too difficult and inconvenient; even a simple tool would be helpful.
I wouldn't know how to make the editing of filters visible.
Or do you only want to add hand picked items?
(2026-11-04, 0:30)Orion Pobursky Wrote: [ -> ]Nice.  I appreciate you working this out. I recently switched to a Linux desktop on my travel computer and the experience has been so good that I might go full time at home as well.
FYI: it is taking a bit longer as I thought it was a fun idea to let a local AI loose on some of the LDCad code  Big Grin
It has some comments I want to take a closer look at.
(2026-11-16, 21:25)Roland Melkert Wrote: [ -> ]I wouldn't know how to make the editing of filters visible.
I think add parts in custom PBG  should be similar to how you add custom parts in favpart , rather than writing PBG code, because that wouldn't allow for visual editing and would be inconvenient.
