I have for a few years been wanting to upscale set 42145 so that it looks right with the lego dune ornithopter blades
But whenever I try by just reading the instruction manual, I either upscale only one or 2 axis and not 3, or I upscale all 3 axis but it looks weird (the wheels were way to far apart)
So, I thought it might be a good idea to have a reference model that is blown up in LDCAD
Therefore I am wondering if this is possible, or would up-scaling a part also shift its position,and then the whole model will look like a salad.
Here is the model
As simple way to upscaledo this: (I hope I got you right)
- open in LDCAD
- select ALL
- right-click > Reorganise > Move to subfile >
- just give it a name
- Main File has now only the sub file
- select the subfile, click into the coordinates
- in the matrix enter the scale that you want (instead ot th "1")
- done
LDCAD will colour it a bit different as this is the way it marks scaled bricks.
(2026-02-17, 21:49)Gerald Lasser Wrote: [ -> ]As simple way to upscaledo this: (I hope I got you right)
- open in LDCAD
- select ALL
- done
This worked, but when I then dragged the subfile into a new ldcad project, any part I drag in is also now up-scaled instead of being at the normal scale.
(2026-02-17, 22:42)SNIPE Wrote: [ -> ]This worked, but when I then dragged the subfile into a new ldcad project, any part I drag in is also now up-scaled instead of being at the normal scale.
They take the matrix of the last used working part (or subfile). If you reset the matrix for the first new piece you add, then subsequent ones should also be normal.
(2026-02-18, 1:54)N. W. Perry Wrote: [ -> ]They take the matrix of the last used working part (or subfile). If you reset the matrix for the first new piece you add, then subsequent ones should also be normal.
Resetting the matrix for every new part I add is a bit tedious, is there a better way?
(2026-02-18, 14:45)SNIPE Wrote: [ -> ]Resetting the matrix for every new part I add is a bit tedious, is there a better way?
You should only have to do it once (you might have to select the part after resetting in order to make that the current working matrix). Or I could be wrong about what's causing the behavior…
PS. I also have a hotkey set up—can't remember if it's the default, or custom—to reset the matrix on a new part as I'm dragging it into the edit window.
