Full Version: LDraw.org 2025-10 Parts Update Now Available
The 2025-10 LDraw Parts Update has been released. This update adds 66 new files to the core library, including 45 new parts and 11 new primitives.
Thanks are due to all the part authors who created or corrected parts for this release. The small, but dedicated, band of reviewers also play an important role in keeping files moving through the Parts Tracker and deserve just as much credit. This update wouldn't have been possible without their dedication and attention to detail.
You can preview the new parts in 2025-10 here, and download the zip-file update or Windows install package here.
Thank you to all the testers and parts authors who continue giving feedback on the PT software. This project would not be what it is without your help.
Orion Pobursky
Magnus Forsberg
Gerald Lasser
LDraw.org Parts Library Admins
Hey just out of curiousity could you help me get rox's hat working aka the sandoga I cant get it working via the custom one I found
(2025-11-30, 5:17)Jake Cowledge Wrote: [ -> ]Hey just out of curiousity could you help me get rox's hat working aka the sandoga I cant get it working via the custom one I found
1. You need to download all the files (download the Zip on the tracker).
2. You need to place the files “correctly”: the main file and the files in the P folder need to be in the same directory, while the files in S should be/stay in the S subfolder.  You only to import the main file, PartDesigner will find the others.
3. If PartDesigner whines about a file missing, you need to find the file, place it correctly (see (2)), and restart PD, otherwise it won't see the changes.
(2025-11-30, 12:44)Sylvain Sauvage Wrote: [ -> ]1. You need to download all the files (download the Zip on the tracker).
Can I see a example of what it should look like? because I have nothing to compare it to currently or where to put it once fixed
Download the Zip from the tracker.
The Zip has this structure:
├── p
│   ├── 4-4cyli.dat
│   ├── 4-4cylo.dat
│   ├── 4-4edge.dat
│   ├── 4-4ring2.dat
│   ├── 4-4ring3.dat
│   ├── 4-4ring8.dat
│   ├── 48
│   │   ├── 1-4cyli.dat
│   │   ├── 1-4edge.dat
│   │   ├── 1-4ring9.dat
│   │   ├── 4-4con25.dat
│   │   ├── 4-4cyli.dat
│   │   ├── 4-4cylo.dat
│   │   ├── 4-4edge.dat
│   │   ├── 4-4ring13.dat
│   │   ├── 4-4ring14.dat
│   │   └── 4-4ring9.dat
│   ├── stud2a.dat
│   └── stud4od.dat
└── parts
    ├── 5987.dat
    └── s
        └── 5987s01.dat
You extract the Zip.
You start PartDesigner.
You choose Import 3D model and go the ‘parts’ folder and you choose 5987.dat.  PD will find 5987s01.dat on its own.
That’s all for 5987.
For other parts, some primitives (from the p folder) may be needed.  In that case, you need to move them to the parts folder before (re)starting PD.
For instance, if when you import 5987.dat, PD say it can’t find 4-4ring9.dat (it won’’t say that! it’s just an example), you move the file from p/48/ to parts and restart PD before trying again.
