Full Version: Duplo treasure map 54073
At first, I thought it was a helix, then maybe a half helix. It seems the shape is something not quite anything mathematical.
Is the mesh available from BI?
https://www.bricklink.com/v2/catalog/cat...P=54073px1
The part has a rectangular indentation on the handle. The injection point is on that rectangular area. Should the rectangular are be modeled or is it part of the injection point?
One end of the handle is intended to fit inside a hollow stud7. Is there a prim for it?
(2025-09-01, 22:37)Peter Blomberg Wrote: [ -> ]At first, I thought it was a helix, then maybe a half helix. It seems the shape is something not quite anything mathematical.
No, it's not there. Much too old. At first I thought it was flat, but it's not. Here you get some (blurry) photos: https://www.ebay.com/itm/275415320473
Quote:The part has a rectangular indentation on the handle. The injection point is on that rectangular area. Should the rectangular are be modeled or is it part of the injection point?
For me, injection point, not worth modeling.
Quote:One end of the handle is intended to fit inside a hollow stud7. Is there a prim for it?
None I know of. Probably not worth a new prim, except if other parts use that connection (is there any???)
(2025-09-01, 22:37)Peter Blomberg Wrote: [ -> ]One end of the handle is intended to fit inside a hollow stud7. Is there a prim for it?
Isn't that the same as a regular stud4 ?
The outside of a stud4 connects to the inside of a stud7. But that pole looks solid, not hollow like a stud4.
Yes, the handle bottom is solid. The ones I have easily on hand are all solid except the fire extinguisher.
Yes, the same feature can be found on e.g. fire extinguisher, maze, fireman's axe, castle axe, and video camera. I'd say we need to create a prim for it.
Also batarang, fuel hose, flintlock pistol, fishing rod, meat cleaver...
(2025-09-03, 4:25)Peter Blomberg Wrote: [ -> ]Yes, the handle bottom is solid. The ones I have easily on hand are all solid except the fire extinguisher.
...so indeed, worth a prim!
I do have the part, but unfortunately no access to it in the near time. (I.e. till the end of the year) so let me know if you are interested in it.
(2025-09-03, 7:39)Philippe Hurbain Wrote: [ -> ]...so indeed, worth a prim!
What name/title/description should the prim have?
Duplo utensil stud bar?
