Full Version: BrickCon presentation
I'm doing a presentation about LDraw at BrickCon in the Seattle as I do every year.
Here's last year's slide show:
https://docs.google.com/presentation/d/1...sp=sharing
This presentation is geared towards the vitual LEGO novice. Any feedback on things that might be worth including would be helpful.
It could use an explanation on how exactly you can bring in up-to-date LDraw library into BL Studio. Right now it just mentions that you can download whole LDraw library via a a one-click download, but doesn't elaborate on what you should do with it after that. Also probably you should mention that parts downloaded this way wouldn't have things like connectivity or collision data, as those are done via BL Studio's own file formats and not extrapolated from LDraw data
Also it says that one of the things the presentation is about is "How can I use my Stud.io creation with other LDraw tools", but I don't see anything like that on the slides
Also also prob it would be a good thing to drop in QR-codes for the links. While they are short and easy to type-in manually, it's still would be more convenient to just scan the code
Also also also it is, well, Studio, not Stud.io - that's just an old link to the website that doesn't even work anymore
