Looking for the Tauntaun arms and body. I see the horns and reins, but no arms or body?
These would be bricklink part numbers 86055, 86056, and 64800.
Thanks in advance!
Dont think so. The horns only exist as they were also used on the Wampa.
(2025-08-09, 8:13)Peter Grass Wrote: [ -> ]Dont think so. The horns only exist as they were also used on the Wampa.
the arms are in bi not sure about the body.
(2025-08-09, 11:20)Jeff Jones Wrote: [ -> ]the arms are in bi not sure about the body.
What is “bi” if I may respectfully ask?
Anyone? Will anyone please tell me what "Bi" is? Thanks.
The LEGO building instruction app which requires some technical expertise to get the meshes from, if they are even there.
(2025-08-23, 3:27)Orion Pobursky Wrote: [ -> ]The LEGO building instruction app which requires some technical expertise to get the meshes from, if they are even there.
Where there is a will....
Thank you by the way, I appreciate the help.
found the arms were under 35201 and 35202
(2026-03-28, 13:40)Jeff Jones Wrote: [ -> ]found the arms were under 35201 and 35202
How would one go about finding those arms exactly? I know how to extract the meshes by loading the set they are included inside, but how would one go about extracting them if you had no set to refer to?
Thanks.
