2025-07-25, 17:08
this version gives you just a pair of small improvements.
![[Image: attachment.php?aid=12753]](https://forums.ldraw.org/attachment.php?aid=12753)
Changelog:
(1 new feature and 1 bug fix)
The following critical issue is fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...see a hint if the part type does not match to its name.
- A recurring subpart reference loop can cause the program to crash or hang.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.95.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.95-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.95.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 150 MB
- Operating System (64bit): Windows 7,8,10,11, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 500 MB
