Full Version: LDConfig Update: More discontinued/Legacy Colours available
A new LDConfig Update is available:
*10 New Colours added (see below)
*Changed Name of "125 Light Orange" to "125 Spud Orange" to avoid confusion with Bricklink Colour
*Added Lego ID to Metallic Light Blue and Metallic Light Pink
Solid Colours:
  • 10015 Lemon (15 Lemon/171 Lemon): All Parts available. Some possible prints in Paradisa and Duplo. Retired 1994.
  • 10017 Rose Pink (17 Rose/56 Rose Pink): Many Plates, Tiles, early Paradisa. Possible Pattern Reworks needed. Retired 1994.
  • 121 Light Orange (121 Medium Yellowish Orange/32 Light Orange): 50% of Parts available. Chef's Hat and 1999 Winnie Pooh. Some Adventurers Prints. Retired in 2004.
  • 123 Dark Salmon (123 Bright Reddish Orange/231 Dark Salmon): All Parts available, all Duplo. Some Life on Mars Prints. Retired 2004.
  • 180 Dark Yellow (180 Curry/161 Dark Yellow): All 5 Parts available, all Duplo. Forum Request. Retired 2006.
  • 213 Medium Blue-Violet (213 Medium Royal Blue/no Bricklink name): Single Part Use (44688). Little Robots. Part Available. Only used in 2003-2004.
  • 220 Light Lilac (220 Light Lilac/246 Light Lilac): Duplo 2x2 Brick and Duplo Figure Parts. Retired ca. 2006.
  • 225 Warm Yellowish Orange (225 Warm Yellowish Orange/172 Warm Yellowish Orange): Single Part Use (6490).Duplo 2004. Part Available.
Pearlescent Metallic Colours:
  • 342 Conductive Black (342 Conductive Black/no Bricklink name): Single Use Color. Ultra Agents Part 15411. Available. Retired 2016. Technically not a Pearlescent Colour, but that seemed the best match.
  • 346 Reddish Copper (346 Copper Metallic/249 Reddish Copper): Ninjago and Friends. Several Parts available. Used from 2017-2020.
EDIT:
According to the Howerter list, both Conductive Black and Metallic Dark Grey use the same Hex Value of 3E3C39...
Any suggestions?
more rubber colors
rubber metallic dark gray, dark purple, pearl gold, dark green, very light bluish gray, trans orange, bright light orange, olive green
(2025-07-09, 1:31)Chris Böhnke Wrote: [ -> ]A new LDConfig Update is available:
Solid Colours:
  • 48 Lemon (15 Lemon/171 Lemon): All Parts available. Some possible prints in Paradisa and Duplo. Retired 1994.
  • 49 Rose Pink (17 Rose/56 Rose Pink): Many Plates, Tiles, early Paradisa. Possible Pattern Reworks needed. Retired 1994.
Please do not fill in missing LDraw numbers when coming across LEGO colors which already are occupied by a historical LDraw number such as LEGOID 15 - Lemon (LDraw 15 -White). Especially when there is a LEGOID such as: LEGOID  48 - Transparent Green. This will increase the confusion an mismatch even more.
The 10000er number have been created to cope with the discrepancy between LEGO/LDraw. The new LDraw number would therefore be:
10015 - Lemon
10017 - Rose
Solid Colours:
EDIT:
Any suggestions?
not all dark yellow parts are available there is 2 missing sw parts
(2025-07-09, 11:06)Willy Tschager Wrote: [ -> ]Please do not fill in missing LDraw numbers when coming across LEGO colors which already are occupied by a historical LDraw number such as LEGOID 15 - Lemon (LDraw 15 -White). Especially when there is a LEGOID such as: LEGOID  48 - Transparent Green. This will increase the confusion an mismatch even more.
10015 - Lemon
10017 - Rose
Changed.
(2025-07-09, 12:11)Jeff Jones Wrote: [ -> ]not all dark yellow parts are available there is 2 missing sw parts
I didn't count prints. Some of Duplo bricks also miss their printed version.
And as far as I can tell, that 2005 Clone Trooper isn't confirmed Curry (comes close to, though).
Should tan and dark tan get added as cloth colours?
does this count as clear rubber or does this need milky white (COLOR 79) as rubber?
https://www.bricklink.com/v2/catalog/cat...0#T=C&C=60
(2025-07-09, 20:26)Rene Rechthaler Wrote: [ -> ]Should tan and dark tan get added as cloth colours?
milky rubber
also add fabric light gray dark red dark gray sand red
https://www.bricklink.com/v2/catalog/cat...only%22:0}
(2025-07-09, 12:42)Chris Böhnke Wrote: [ -> ]I didn't count prints. Some of Duplo bricks also miss their printed version.
https://youtu.be/STSOAsjK9nA?si=OBqWW6H8giU8N2ji&t=877
book confirms it
(2025-07-25, 19:55)Jeff Jones Wrote: [ -> ]https://youtu.be/STSOAsjK9nA?si=OBqWW6H8giU8N2ji&t=877
book confirms it
Ok, I'm convinced  Blush
