Full Version: 500 Server error
When I try to upload a part I get a screen with a "500 Server Error" message. I was able to upload the subfiles, but not the parts.
https://library.ldraw.org/parts/46476
https://library.ldraw.org/parts/46477
It also says "28694.dat: To submit a change to a part already on the Parts Tracker, you must check "Replace existing file(s)" but there is no fileĀ 28694 on the Parts Tracker. When I tick "Replace existing file" I recieve theĀ "500 Server Error" message.
Kind regards,
Lisa
I'm only guessing, but check for a typo in the header.
I checked with DatHeader. All good. These are the files.
Kind regards,
Lisa
There some glitch happen when this part was uploaded. I'll get it fixed but not until I'm back from vacation on Friday.
I found the error: there was a space in your username in the history line. "Lisa Winter" vice "LisaWinter". The error check should catch this but didn't for some reason. I've resubmitted the 2 parts for you.
Thank you very much.
Kind regards,
Lisa
