Full Version: Duplo 65110
I made the attached draft, but it shows my limits in making an accurate model of all the curvature on this part. It has far too many flat surfaces. The real part is much more round on the cushion part. I inlined subfiles. The current draft uses the s\65109s01.dat subfile for the underside, but it is rather different from the real part. Is this draft worth the dust bin or can you suggest how to improve it?
[attachment=12746]
[attachment=12747]
(2025-04-24, 16:11)Peter Blomberg Wrote: [ -> ]I made the attached draft, but it shows my limits in making an accurate model of all the curvature on this part. It has far too many flat surfaces. The real part is much more round on the cushion part. I inlined subfiles. The current draft uses the s\65109s01.dat subfile for the underside, but it is rather different from the real part. Is this draft worth the dust bin or can you suggest how to improve it?
I find your draft pretty nice!
But if it can help, this part is available in Unity microgame, here's a conversion...
