the two 5.5 axles you mentioned are correct...
(the older 32209 has the long end at X=53 and the other one is not rounded)
for the other parts: not all old parts with sharp ends have been reworked yet.
for the snap: maybe it can be added to the shadow library...
(2025-12-03, 0:46)SNIPE Wrote: [ -> ]And probably the axle for small linear actuators and the micro pullback motor brick
Do you have the number on these?
The axles
are different.
attachment=13491]
both fixed, also the other pullback brick axle
(2025-12-03, 16:42)Rene Rechthaler Wrote: [ -> ]for the snap: maybe it can be added to the shadow library...
I've added the shadow info for the new axles to the github repository.
https://github.com/RolandMelkert/LDCadShadowLibrary
Just download the code zip and rename it to offLibShadow.csl or update the ldraw path config to point to the new zip.
(2025-12-04, 23:36)Roland Melkert Wrote: [ -> ]I've added the shadow info for the new axles to the github repository.
Thanks, this improved it a lot.
Here are most of the LDRAW parts that have axle errors:
no cap:
19474-f2.dat
19474-f1.dat
19474-f3.dat
43373.dat
15362.dat
47298.dat
11641.dat
no snapping:
5794.dat
5713.dat
7222.dat
7244.dat
4192.dat
15107.dat
55706.dat
4042.dat
54272.dat
98135.dat
11305.dat
18396.dat
18396p03.dat
18396p01.dat
18396p02.dat
42074.dat
3627.dat
87788.dat
92202.dat
40341.dat
40582.dat
11164.dat
7222.dat
4192.dat
28222.dat
53568.dat
87820.dat
53562.dat
48253.dat
49700.dat
u9068.dat
2426c02.dat
74569.dat (but 2838c01.dat does)
74569p02.dat (but 2838c01.dat does)
74569p01.dat (but 2838c01.dat does)
72892.dat (but technicFlexAxle4L2L-1.ldr works fine)
cap in wrong place:
32506.dat
61100.dat
89509.dat
2601.dat
32506.dat
32167.dat
(2025-12-12, 18:24)SNIPE Wrote: [ -> ]Thanks, this improved it a lot.
Some of those 'no snapping' parts are unofficial and do have snapping info in the latest git shadow.
Are you sure your unofficial library is ALSO pointing to the same shadow file?
Also I can't find some of those numbers, like:
92202.dat
5794.dat
Not even on the part tracker
(2025-12-12, 18:50)Roland Melkert Wrote: [ -> ]Also I can't find some of those numbers, like:
92202.dat
5794.dat
Oh they will be from digital bricks actually.
my shadow
lib is up to date and ldcad is pointing to it yeah
ill check closely tomorrow
part 28974a.dat is missing a tiny detail,
On the real part there is a tiny circle protruding outwards:
This protrusion is not present in LDCAD:
![[Image: E29-CCDC6-185-F-4212-8-E21-4-FA4-FA4445-BD.png]](https://i.ibb.co/Ng1ccqty/E29-CCDC6-185-F-4212-8-E21-4-FA4-FA4445-BD.png)
That part has seen many revisons by Lego themselves.
Do you know which version your's is from?
At first glance I'd say it's simply a "molding relict" which is typically not rendered in LDraw.
It looks like an "Ejection Mark", meaning it's a stamp left on the part when it is thrown out of the mold (by metal ejection pins) after being cooled down. Those typically have no function (in the final part) and as such are not rendered in LDraw.
EDIT:
Ok, that can't be an Ejection Mark. It still seems to have no direct function... How does it look on a minifig?
Also those holes are more interesting than the protrusion I'd say...
Part 80910 does not have barholes or accept a bar
The axleholes do, but bars stop at 1L, however LDCAD is allowing them to go 2L in.
So we need to make the barhole fractionally smaller and cap the axle hole off, 2L axle joiners do this fine.
I also have added snapping to a few parts that had it missing, I will add them on the tracker once I get submit privileges
(2026-03-09, 9:17)SNIPE Wrote: [ -> ]The axleholes do, but bars stop at 1L, however LDCAD is allowing them to go 2L in.
There's no need to change the LDraw part, you only need to define proper connectivity for it (axle holes work by inheritance, but they need an axlehole stop)
Quote:I also have added snapping to a few parts that had it missing, I will add them on the tracker once I get submit privileges
The tracker only defines geometry, for snapping information you need to add them to LDCad shadow library Github:
