(2019-07-07, 22:55)Gerald Lasser Wrote: [ -> ]I checked all the updates, I only find it in its initial release here: LDraw.org Parts Update 2009-02 - Sep 16, 2009
may be still on your HD?
I just checked every backup I have. If it ever existed, it's gone now.
(2019-07-07, 16:01)Gerald Lasser Wrote: [ -> ]Another part used in the Quantum Real Explorer that needs a rework, is the Brick 1 x 1 x 2/3 Round with Bar and Clip Vertical (Part 4735)
Currently the grooves on the part are only edge lines, which make it appear smooth during renders. I have reworked it, added proper grooves and a different clip. The clip needs to be a bit narrower though...
with narrower clip
Mom not a fan of the sharp ridges. The real part is more rounded. Maybe torii instead?
(2019-07-07, 23:38)Orion Pobursky Wrote: [ -> ]Mom not a fan of the sharp ridges. The real part is more rounded. Maybe torii instead?
Since the part is so small, I can't be absolutely sure, but I don't think they are rounded. I think they are rectangular grooves with a flat outside. And using tori for features so small would be serious overkill. I think the walls of the divots are too sloped (should be closer to 90 degrees), resulting in the outer parts being too skinny.
Here's a hi-res picture of the part. It'S more a trapezoid shape. I also don't like too sharp edges, but using tori here would give us a LOT of quads...
attachment=3828]
I go ahead with those measurements, the indents will be shallower then as I used 1 LDU in the mock-up vs. 0,5 I get from the picture
You might check what I did on 71342.dat
Minifig Bugle.
(2019-07-08, 6:42)Gerald Lasser Wrote: [ -> ]Here's a hi-res picture of the part. It'S more a trapezoid shape. I also don't like too sharp edges, but using tori here would give us a LOT of quads...
I'd clearly go with the trapezium method, like s\604547s01.dat with the right ridge scaling. More is pure overkill at this scale.
(2019-07-08, 8:58)Gerald Lasser Wrote: [ -> ]@all, thanks for your opinions, I go ahead with this one
Isn't this very close to the minifig tool handle?
Spanner, screwdriver, hammer. 6246a-f and 11402a-i
That design is placed in subfiles. Could they be used?
(2019-07-08, 11:31)Magnus Forsberg Wrote: [ -> ]Isn't this very close to the minifig tool handle?
No, they have one too many groove...
I tried looking them up as well
Imho, bottom of grooves cylis are just wasting triangles (though you caould use a single cyli for whole length...)
(2019-07-08, 11:49)Gerald Lasser Wrote: [ -> ]No, they have one too many groove...
You could just have one groove as a primitive/subfile.
(2021-04-13, 11:52)ashishkumarji Wrote: [ -> ]I think that we can't simply correct geometry
I think that you're a spammer. Be careful.
71708 has some strange sections that are always red no matter what colour I make the part:
![[Image: c9EWAqm.png]](https://i.imgur.com/c9EWAqm.png)
I checked my settings in LDCAD and nothing changes it, and also reinstalled the official and unofficial LDRAW libraries.
Regards, Snipe
As this is an unofficial part, I would suggest redownloading it.
(2023-05-12, 15:00)Orion Pobursky Wrote: [ -> ]As this is an unofficial part, I would suggest redownloading it.
Yes. I have a weird colored version too, but the one on PT is correct.
(2023-05-12, 15:59)Philippe Hurbain Wrote: [ -> ]Yes. I have a weird colored version too, but the one on PT is correct.
In comments, there was a hard coded surface that was corrected on 5/10. So if it was download before then, then you probably have an error.
(2019-07-08, 1:03)Travis Cobbs Wrote: [ -> ]Since the part is so small, I can't be absolutely sure, but I don't think they are rounded. I think they are rectangular grooves with a flat outside. And using tori for features so small would be serious overkill. I think the walls of the divots are too sloped (should be closer to 90 degrees), resulting in the outer parts being too skinny.
I need to finally fix it, it has still some other issues
I downloaded the file on its own rather than the entire library, now it works, thx.
(2019-06-26, 11:43)Gerald Lasser Wrote: [ -> ]I noticed yesterday that the snowshoe, coming with the current Arctic Sets, is actually another type.
Now comes the dilemma. In our library there is the 30284, the original one and the 11187 which is currently listed as an alias.
At BL and Brickset however, the 11187 is NOT the same design as the 30284. Moreover there is another variant, the 28263, which is an alias to 11187.
The 11187 is official, but in reality it has another origin that 30284. Compared to 30284 it has a short front end and a long backend.
Ideal would be to change 11187 to the correct geometry and add an alias for 28263.
With that approach a complete compatibility cannot be guaranteed due to the different lenghts and existting models may face collision issues (though I think there is only a slim chance...)
To sum what we currently have:
30284 - Minifig Snowshoe - The real thing - Official
11187 - =Minifig Snowshoe - Wrong alias as this is actually the short version - Official
11187a - Minifig Snowshoe with Short Toe Webbing - The real thing - Unofficial
28263 - =Minifig Snowshoe with Short Toe Webbing - Alias to 11187a - Unofficial
I has been suggested to obsolate 11187 (which have never been done) and release 11187a and 28263 as official short versions. To get away from the 11187-mess I suggest:
* Obsolate 11187 as suggested
* Make 28263 the offiicial short version
* Make 11187a the alias of 28263
Thoughts?
I'm fine with this scheme.
Hi, I'm new here, so if this is the wrong spot for this, just say so.
The Chrome Visor piece (part 769,
https://library.ldraw.org/official/12552) has "incorrect" perfectly straight geometry on its lower half, which causes any rendered reflections to be stretched, as shown here:
https://www.flickr.com/photos/thebrickcc...3497541138
However, the real-life piece is rounded all the way down, resulting in natural-looking reflections, as shown here:
https://www.flickr.com/photos/ironbricks/6008252805
It would be nice if the 3D model could be fixed to match the real piece by adding just a bit more curvature and more triangles on the lower half of the visor. Kind of the entire reason this piece exists is because of its crisp, shiny reflections, so I think fixing this aspect of the piece should be somewhat of a priority.
I have created a very rough fix in Maya, demonstrating that this is possible (it still has some stretching on the bottom though, since my 3D modelling skills are severely lacking):
https://www.flickr.com/photos/thebrickcc...3498379547
But it would be amazing if someone who actually knows what they are doing could take a shot at fixing this.
I would say it is flat, but the geometry could be improved. The angle of the bottom front surface is not right.
The green arrow show that the surface in a fresh download of part 23318 is more tilted.
attachment=10957]
This could be fixed, but not until someone decide to also correct the bad shape on helmet 2446.
https://forums.ldraw.org/thread-26653-po...l#pid47475
(2024-01-31, 22:05)Magnus Forsberg Wrote: [ -> ]I would say it is flat, but the geometry could be improved. The angle of the bottom front surface is not right.
While the rendering looks wrong, I don't think it's due to incorrect LDraw part geometry. As Magnus points out, the real helmet really isn't flat, and I'm pretty sure this is visible in your photo:
attachment=10958]
The red arrow I added certainly appears to point at the spot on the helmet where it changes from spherical to cylindrical. Notice how the apparently linear features in the reflection change direction at that spot.
Thanks for responding! I think you're right and it definitely looks somewhat flat in real life.
From what I understand, it's more of an issue with the seam in the reflection that is present due to the 3D geometry abruptly switching from spherical to cylindrical. (Here's the best explanation I can find of what causes the seam in the reflection:
https://www.youtube.com/watch?v=jvPPXbo87ds&t=1736s
it's talking about flat planes, but if I understand correctly, it should also apply to this piece, where a sphere transitions to a cylinder.)
That's why I was wondering if this piece could get even just the slightest bit of curvature on its lower half---it wouldn't take away all the stretching, but it would smooth it out and make it more like its real-life counterpart.
Also that's kind of crazy how much is left to fix on the helmet model, I had no idea...
(2024-02-01, 11:07)Grey Wrote: [ -> ]Also that's kind of crazy how much is left to fix on the helmet model, I had no idea...
An updated and reworked helmet and visor is now available on the Part Tracker.
Look for parts helmet 30124b and visor 71016.
50903 has a overlapping primtive
can one of the pros maybe fix 864s01.dat?
it has lots of overlaps and open subpart ends...
the moving tongue is also missing, and it is the base of all 12V track switches.
Does anyone have a broken one to disassemble it? i guess blue and grey have the same track base, just different mechanisms outside...
Hi, I'm not sure if I'm the only one to notice, but the part 4045
https://library.ldraw.org/parts/32423 is supposed to be
1x4x1 not 1x4x1 1/3. See reference:
https://rebrickable.com/parts/4045/brick-curved-1-x-4-x-1-curved-sides/
I guess this part was created by joining 2x 1871 + half 6191 before the actual model was available to download from the instructions app and somehow it slipped through the release check. Would someone please fix it since it's also in the official BDP palette like this.
I stumbled around this error by accident, because I rebuilt the Soap Box Racer from the M&T event in Studio and the brick height seemed off compared to the official image.
![[Image: XUdbUGX.png]](https://i.imgur.com/XUdbUGX.png)
maybe we can integrate the sphere prims when reworking...
do we even need a (new) prim for the bottom cutout?
are we sure this is the same part? or are there two similar parts with different heights?
(2025-01-13, 22:46)Rene Rechthaler Wrote: [ -> ]maybe we can integrate the sphere prims when reworking...
Yes, I'm sure it's the same part and there are not two different height versions. It was only released in 2023.
For 2025, there will be a new wave of similar curved bricks with 1 module height as well, so it makes sense to make a new prim for the 1/8 sphere.
https://www.newelementary.com/2025/01/what-are-new-lego-parts-in-january-2025.html
My bad. I made this on images alone.
Will rework it as 4045b.
11217 should have subfiled for paterns and antistud should have geometery removed to avoid collission with 3626
Part 32197 misses a lot of condlines
the zigzags on the tyre have an additional zigzag around (they are changing their position)
hard to explain, but the ~ in the tread isnt always on the same heigth, it wobbles sideways when rotating...
attachment=12549]
the two "return" curves are changing their sideways position
(but my parts are stowed away too well to check how many waves are there on the full tread)
(2025-02-20, 18:01)Rene Rechthaler Wrote: [ -> ]the zigzags on the tyre have an additional zigzag around (they are changing their position)
I found this picture that makes it more obvious (top):
http://www.technicopedia.com/8448/8448diff.JPG
The above picture comes from this page:
http://www.technicopedia.com/8448.html
Note: technicopedia is http-only, no https support so embedding the image in the post didn't work.
many of the hair pieces on the tracker are missing edgelines in their strands
example anakin's hairpiece
here's what the one on the tracker looks like
attachment=12552]
here's what's it supposed to look like
attachment=12553]
and here's the bi mesh
attachment=12554]
the 3901 in the tracker currently has bad geometry, too short hairline is too flat
while bi version does fix the 2 issues it has werid lines on the sides
i think 35693 is the best, it doesnt have these werid lines and has lines for that werid hair pattern, but it has a hole, best case scearnio is subpart it and recreate 3901 using it
I have noticed that part BrickLink 60616pb015 / official part 60616bdx0.dat is incorrect.
https://library.ldraw.org/parts/10723
The sticker is on the wrong side of the door.
ldraw page vs instruction book:
Parts 4265a, 4273a & 4262 all have toothed elements and I think they are supposed to be able to mesh together. But the models teeth do not line up on any of the 3 parts with each other without collision errors.
Does anyone have these parts to test it?
(2025-10-12, 8:13)Peter Grass Wrote: [ -> ]Parts 4265a, 4273a & 4262 all have toothed elements and I think they are supposed to be able to mesh together. But the models teeth do not line up on any of the 3 parts with each other without collision errors.
Could you please give an example?
1 39 0 0 0 1 0 0 0 1 0 0 0 1 4262.dat
1 14 -30 0 -36 -1 0 0 0 1 0 0 0 -1 4265a.dat
1 39 -30 0 -50 1 0 0 0 1 0 0 0 1 4273a.dat
1 14 -25 0 -70 0 0 -1 0 -1 0 -1 0 0 4265a.dat
1 14 -50 12 0 0 1 0 0 0 -1 -1 0 0 4265a.dat
1 14 50 17 0 0 1 0 0 0 -1 -1 0 0 4273a.dat
didnt find collisions, but the teeth outside end and inside end to the cylos cause gaps on prim subst (we could add some erings)
(2025-10-12, 9:30)Rene Rechthaler Wrote: [ -> ]didnt find collisions, but the teeth outside end and inside end to the cylos cause gaps on prim subst (we could add some erings)
When I was looking at them in studio and connecting them how you would in real life with a half pin I did have some of the parts clipping in to each other slightly. I will have to see if studio is using the latest version of the parts.
Some of the axles no loner have snapping after they were updated to have rounded ends.
Also some have rounded ends when they should still have square ends, Here is one example:
https://library.ldraw.org/parts/5643
also the old 5.5L axle is slightly shorter than the newer mold.
And probably the axle for small linear actuators and the micro pullback motor brick
This image should help, The left end of the bottom axle is less rounded off.
![[Image: 400x200.jpg]](https://rebrickable.com/media/thumbs/uploads/partnotes/32209.jpg/400x200.jpg)
