I need a 1-6 ring primitive. It does not yet exist in the size I need or any size near the correct size. Which option is best?
a) create the 1-6 ring as a new primitive,
b) combine a 1-8 ring primitive with a rotated 1-24 ring primitive (both exist in a nearby size),
b) use the 1-8 ring as primitive and add the two missing segments as quads,
c) define all segments as quads, i.e. not use primitives.
1-6 is hi-res?
what size do you need? for what? are there other prims (cyli/o/c or disc/chrd/ndis) next to it?
you can generate prims yourself with the PrimGen (included in the LDPE)
there you can define inner/outer diameter and let it generate the prim...
maybe also check the rings+cones tool in LDPE to check if it can be done with something else.
generally speaking every prim that is required and is smaller that 1-4 can/should be create if it is not existing. Try to avoid to rotate prims by anglesĀ other than 90 deg to make a another one, e.g. combinign ring primitives.
As Rene suggested use the PrimGen of LDPE to generate it.
Thanks for the replies. I will henceforth create any missing prim smaller than 1-4.
(2025-03-09, 8:47)PeterĀ Blomberg Wrote: [ -> ]Thanks for the replies. I will henceforth create any missing prim smaller than 1-4.
Unless they are used by a part, please do not submit them to the tracker. We do not release primitive that are not in use and they will languish on the tracker. Note: there may be some out there that have been used previously but are no longer but that's an edge case.
Indeed. Only the prims which are needed for a part on the tracker.
