Full Version: Numbering advise for 32094
Looking at finishing the container from the Cybermaster set, part ID 32094.
How should I number this? I now have the different sections as k01, k02 and k03 (k04 to be done), and the combination as -f1 and -f2 (collapsed/folded)
Advise on this would be most helpfull.
[Image: 32094-f21.png]
This was the only image I found. If I understand it correct, I think you have a good solution.
Place the origin of the sections in their rotation points.
https://brickshelf.com/gallery/D-Dennis/...8483-1.jpg
There is a similar part, 86501, Container Fold-Out Race Track Case.
But that file is using subfiles, and is "locked", not possible to inline and change the shape of it. Maybe it could be changed?
Don't think we had the Flexible_Section solution back then.
(2025-01-07, 21:32)Magnus Forsberg Wrote: [ -> ]This was the only image I found. If I understand it correct, I think you have a good solution.
We didn't indeed, I guess it needs some moved to...
If that can help, I have the 32094 at hand.
(2025-01-08, 8:43)Philippe Hurbain Wrote: [ -> ]We didn't indeed, I guess it needs some moved to...
...and BTW how should I do that? make a moved to from subpart to flex segment part? or obsolete the subparts and resubmit them as flex segments?
Thanks for the feedback, I have the part myself. Maybe I will give the other cybermaster parts a try as well  Smile
(2025-01-08, 17:30)Evert-Jan Boer Wrote: [ -> ]Thanks for the feedback, I have the part myself. Maybe I will give the other cybermaster parts a try as well  Smile
Oh that would be nice...
Made a brick-built prixy to build the set but these arent allowed here
