2024-10-18, 2:31
Just opening LPub3d still gives me these errors...
What is wrong, please?
Thanks,
Franklin
Thanks,
Franklin
LPub3D Annoatation File
Regular expression pattern was not found in titleAnnotations.lst.<br>Be sure the following lines exist in the file header:<br># File: titleAnnotations.lst<br># The Regular Expression used is: ^(\b.*[^\s]\b:)\s+([\(|\^].*)$<br>(file: titleAnnotations.lst)
Ignore Abort
Regular expression pattern was not found in freeformAnnotations.lst.<br>Be sure the following lines exist in the file header:<br># File: freeformAnnotations.lst<br># The Regular Expression used is: ^(\b.*[^\s]\b)(?:\s)\s+(.*)$<br>(file: freeformAnnotations.lst)
Ignore Abort
LPub3D - Excluded Parts
Regular expression pattern was not found in excludedParts.lst.<br>Be sure the following lines exist in the file header:<br># File: excludedParts.lst<br># The Regular Expression used is: ^(\b.*[^\s]\b)(?:\s)\s+(.*)$
OK
LPub3D - Substitute Parts
Regular expression pattern was not found in pliSubstituteParts.lst.<br>Be sure the following lines exist in the file header:<br># File: pliSubstituteParts.lst<br># The Regular Expression used is: ^(\b.*[^\s]\b:)\s+([\(|\^].*)$
OK
OK
OK
