Full Version: app closes, does not process file
I've got an 18 kb MPD file that LPub refuses to open. Whenever I try to open the file in LPub, the application just spins its wheels for a few seconds, and then closes, without any kind of error message.
This same file works perfectly fine in LDView, FWIW...
Thanks,
Franklin
Would you be willing to post the file so we can see if we can replicate the problem?
Here it is.
[attachment=11999]
Thanks,
Franklin
(2024-10-14, 22:21)Franklin W. Cain Wrote: [ -> ]Here it is.
Thanks,
Franklin
I can open it okay in LPub3D, so perhaps it is something specific to LPub?
From just casting my eye over the file, line 300 does look a bit suspect, perhaps missing a leading //? Perhaps that is the cause of the hang?
David
I am also not getting any errors.
Do you have latest version installed:
https://github.com/trevorsandy/lpub3d/re...continuous
(2024-10-15, 0:20)Orion Pobursky Wrote: [ -> ]Do you have latest version installed:
Doesn't look like it.  >__<
When I click on "Check for updates" it just flashes a pop-up which then disappears.
Since my version will not update itself, do I just download one of those files you linked?
Where is the "install" file, please?
Progress, of a sorts...
The app loads my file, now, but I get a couple of error messages with every page.
(What is Excluded Parts any way? If it's in the LDraw library, I'm using it!)
Addendum:
The app does not recognize 3023b as a legit part, if this helps diagnose the problem...
(2024-10-15, 3:59)Franklin W. Cain Wrote: [ -> ]Progress, of a sorts...
Addendum:
I think that is a "feature" of LPub3D having its own copy of complete.zip. The following might resolve the 3023b absent part issue (on the rash assumption you are using Windows):
  1. In Windows explorer, navigate to %APPDATA%\..\local\lpub3d software\lpub3d\libraries
  2. Rename complete.zip to something like old_complete.zip
  3. In Windows explorer, navigate to %LDRAWDIR%. Hopefully it will take you to the directory something like C:\Users\Public\Documents\LDraw
  4. Copy complete.zip from this folder
  5. Navigate back to %APPDATA%\..\local\lpub3d software\lpub3d\libraries
  6. Paste the copied complete.zip into the directory
  7. Fire up Lpub3D
If that doesn't resolve the issue, delete the copied complete.zip from %APPDATA%\..\local\lpub3d software\lpub3d\libraries and rename old_complete.zip back to complete.zip
David
(2024-10-14, 20:48)Franklin W. Cain Wrote: [ -> ]I've got an 18 kb MPD file that LPub refuses to open. Whenever I try to open the file in LPub, the application just spins its wheels for a few seconds, and then closes, without any kind of error message.
Only weird thing i noticed is content in-between 0 NOFILE and the next 0 FILE, maybe lpub doesn't like that?
LDCad log:
06626 | 2024-10-15_23:04:21 | Progress | LDraw file load | D:\downloads\Lab ship.mpd | Starting
06627 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 29 | Content after "NOFILE" without leading "FILE", ignoring.
06628 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 70 | Content after "NOFILE" without leading "FILE", ignoring.
06629 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 114 | Content after "NOFILE" without leading "FILE", ignoring.
06630 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 172 | Content after "NOFILE" without leading "FILE", ignoring.
06631 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 213 | Content after "NOFILE" without leading "FILE", ignoring.
06632 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 272 | Content after "NOFILE" without leading "FILE", ignoring.
06633 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 285 | Content after "NOFILE" without leading "FILE", ignoring.
06634 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 291 | Content after "NOFILE" without leading "FILE", ignoring.
06635 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 297 | Content after "NOFILE" without leading "FILE", ignoring.
06636 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 315 | Content after "NOFILE" without leading "FILE", ignoring.
06637 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 369 | Content after "NOFILE" without leading "FILE", ignoring.
06638 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 371 | Content after "NOFILE" without leading "FILE", ignoring.
06639 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 416 | Content after "NOFILE" without leading "FILE", ignoring.
06640 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 418 | Content after "NOFILE" without leading "FILE", ignoring.
06641 | 2024-10-15_23:04:21 | Warning  | LDraw file load | D:\downloads\Lab ship.mpd | line 428 | Content after "NOFILE" without leading "FILE", ignoring.
06642 | 2024-10-15_23:04:21 | Info    | LDraw file load | D:\downloads\Lab ship.mpd | File is a multi part document (MPD), containing 21 subfiles.
(2024-10-15, 4:22)David Manley Wrote: [ -> ]I think that is a "feature" of LPub3D having its own copy of complete.zip. The following might resolve the 3023b absent part issue (on the rash assumption you are using Windows):
  7. Fire up Lpub3D
Did this... No joy.  >__<
Here are the error messages I keep getting:
Regular expression pattern was not found in titleAnnotations.lst.
Be sure the following lines exist in the file header:
# File: titleAnnotations.lst
# The Regular Expression used is:
^(\b.*[^\s]\b:)\s+([\(|\^].*)$
(file: titleAnnotations.lst)
Regular expression pattern was not found in freeformAnnotations.lst.
# File: freeformAnnotations.lst
^(\b.*[^\s]\b)(?:\s)\s+(.*)$
(file: freeformAnnotations.lst)
Regular expression pattern was not found in excludedParts.lst.
# File: excludedParts.lst
Regular expression pattern was not found in pliSubstituteParts.lst.
# File: pliSubstituteParts.lst
Thanks,
Franklin
- Go to Configuration -> Preferences
- In the General tab, make sure the path to your LDraw directory is correct (mine, for example, is D:\Lego\LDraw)
That's literally all I've done since I download LPub3D the other day to test.
