I've created several groups with custom centres in my LDCad model to make it easier to rotate these about hinge parts. However, I now want to move/rotate parts within some of these groups without having to ungroup/regroup every time. Is this possible? I tried activating nested editing, but that only works for sub-models, not groups.
Thanks.
Ah, I just found how to: Edit {right-click on editing area} > Grouping > Grouping layer > 0: none/disabled
Cheers.
(2024-07-20, 12:21)G.D. Grant Wrote: [ -> ]Ah, I just found how to: Edit {right-click on editing area} > Grouping > Grouping layer > 0: none/disabled
Cheers.
Would love to have hotkeys available for this menu!
(2024-07-20, 17:44)N. W. Perry Wrote: [ -> ]Would love to have hotkeys available for this menu!
You can assign a hotkey to any menu, right click on menu bar -< hotkey config.
Filter on 'grouping' to find the menu.
(2024-07-20, 19:05)Roland Melkert Wrote: [ -> ]You can assign a hotkey to any menu, right click on menu bar -< hotkey config.
Well, not the menu itself, but the items in it. Currently I don't believe you can assign a hotkey to select (or disable) grouping layers.
(2024-07-20, 23:38)N. W. Perry Wrote: [ -> ]Well, not the menu itself, but the items in it. Currently I don't believe you can assign a hotkey to select (or disable) grouping layers.
I see, those items are generated so not part of the default shortcut handling.
I'll see if I can easily add something similar to the rotation/move step shortcuts.
