Hi all,
Now that Studio’s Eyesight has been
open sourced, I managed to build and run it natively on Linux 🥳 and to make Studio use it seamlessly 🥳🥳 and with the GPU too 🥳🥳🥳🥳
If someone wants to give it a try, I wrote
a howto.
(2024-05-02, 14:52)Sylvain Sauvage Wrote: [ -> ]Now that Studio’s Eyesight has been open sourced,
If someone wants to give it a try, I wrote a howto.
I can't find a link to download Eyesight source on BrickLink publicsite (and linked thread on BrickLink Forum requires to login), but the link in the howto works. Thanks.
Guess, howto info and download link should be added to Eyesight's wiki page:
https://wiki.ldraw.org/wiki/Eyesight
Note that, Eyesight, as a fork of Blender Cycles (licensed under GPL), should be open-source by default from the initial release of this fork.
There's no repo, the page is linked in the forum post.
(2024-10-10, 16:36)Orion Pobursky Wrote: [ -> ]There's no repo, the page is linked in the forum post.
Maybe, I don't know as I'm not logged in into BrickLink (and forum is not public).
But on BrickLink public site there is no info on open-source parts of BL Studio, except for the FFMPEG (LGPL-licensed), that is mentioned as used by render (i.e. by Eyeseight):
And nothing about Eyeseight licensing (Cycles render source is under Apache 2.0, that has been changed from GPL in 2013), and there was no announcement on releasing the source in a form of public blog or news post elsewhere except here and in the same thread on Eurobricks, which are based on non-public BrickLink forum post.
There was also a 2021 thread on Blender DevTalk, unveilng that they even included bits of GPL-source in closed source BL Studio (not sure it was just in Eyesight render, or in another part of BL Studio):
https://devtalk.blender.org/t/on-what-ve...ased/17566
Quote:Got bored, did some digging in their binary, they built using some of our our svn libraries (I know it’s our libs since the paths embedded for some of the source files are local to my computer
light_smile: ) which makes it easy to track down
they ship openimageio 1.7.15 which means the code is likely from somewhere in between 2017-06-04 and 2018-08-27 which is indeed around the 2.79 time frame.
It would have been nice if they kept the code opensource, so it could get all the improvements blender makes easily, but they seemingly chose not to go that way. which is somewhat strange since they clearly lifted the GPL licensed bf_blenlib [1] so the closed source nature of eyesight is odd to say the least.
[1] the executable contains strings like Code:
Error! Could not get the Windows Directory - Defaulting to Blender installation Dir! , Error! Could not get the Windows Directory - Defaulting to first valid drive! Path might be invalid! and BLI_dynstr_append text too long or format error.
that can only could have come from bf_blenlib
Anyway, link to
https://blstudio.s3.amazonaws.com/Eyesight/Eyesight.zip and
http://slswww.free.fr/build_linux.html should be added into Eyesight's page on LDraw Wiki.
Also, the "How to" article and linked files in it should be backuped while they are accesible now.
I would like to quote your old tweet:
https://twitter.com/billtfish/status/163...9076057089
Quote:The https://Stud.io has been historically bad with attribution of their sources. LDraw had to contact them directly to get them to acknowledge use in their about page and most average users still don't know that the Stud.io's library is back by LDraw
UPDATE: I found a public page where the BL Studio used sources linked:
https://www.bricklink.com/help.asp?helpID=2079
Quote:BrickLink uses:
All pages use UTF-8 encoding.
BrickLink is hosted by Amazon Web Services.
BrickLink Studio & PartDesigner use:
I assert that the BL forum is public, anybody can create an account. It's not even that onerous of a process requiring minimal info from you.
Regardless, here's the another publicly available page where the source is linked:
(2024-10-10, 17:45)Orion Pobursky Wrote: [ -> ]Regardless, here's the another publicly available page where the source is linked:
You commented just one minute faster, when I edited my previous comment with adding this page, as I just discovered it too.
But, as you can see even this help page is not mentioned on BL Studio main page:
(where only FFMPEG is mentioned, while in same time it is not mentioned on linked
https://www.bricklink.com/help.asp?helpID=2079)
(2024-10-10, 17:38)Eugen Wrote: [ -> ]I would like to quote your old tweet: https://twitter.com/billtfish/status/163...9076057089
I'm aware of my tweet and I stand by it.
In this case, just like with LDraw, it took some arm twisting but they eventually did the right thing.
I can simultaneously be satisfied with their current actions, disappointed that it took community pressure, and wish they would do more to support the community that enables them.
About the absence of link: The link to Eyesight’s source code was in the paragraph about Eyesight on Studio’s download page (where there’s only ffmpeg now).
The page was re-written recently. I’ll ask if dropping the link was intentional.
About the rights: It’s sad to say but “borrowing” things without acknowledgement is the least of the infringements that are SOP in some branches of the software industry. Remember Studio was created (when BL was owned) by a game company and Eyesight was subcontracted to another company (it’s not me, it’s the subcontractor…). They indeed needed to be pressured to do the right thing but they eventually did.
(2024-10-10, 19:13)Sylvain Sauvage Wrote: [ -> ]About the absence of link: The link to Eyesight’s source code was in the paragraph about Eyesight on Studio’s download page (where there’s only ffmpeg now).
If you would contact them, ask them to move link to FFmpeg sources used to the
https://www.bricklink.com/help.asp?helpID=2079 page, and on Studio Download page just add the next note instead:
"The list of used sources can be found at the Help Center accesible via the next link: https://www.bricklink.com/help.asp?helpID=2079"
Hey Sylvain!! Thank you SO much for putting this info out on the public internet. I've been using your guide over the last few weeks to get eyesight building inside a docker container, theoretically opening it up to being deployed anywhere! I'm considering spinning up a monster aws machine / container / whatever (I honestly could stand to learn more about AWS's container compute offerings heh) just to see how fast we could possibly spit out a render.
Let me know if you want access to the github repo! I have it marked private for now, but I'll likely open up the repo once I clean up the commit history and make sure it has only an acceptable amount of PII lol.
(2025-09-12, 22:57)Spencer Wrote: [ -> ]Hey Sylvain!! Thank you SO much for putting this info out on the public internet. I've been using your guide over the last few weeks to get eyesight building inside a docker container, theoretically opening it up to being deployed anywhere! I'm considering spinning up a monster aws machine / container / whatever (I honestly could stand to learn more about AWS's container compute offerings heh) just to see how fast we could possibly spit out a render.
Glad it’s of some use
I don’t know squat about AWS containers, so I wouldn’t be of much help there, but don’t hesitate to ask about anything else, I can always answer “I don’t know”
I am very interested in a Docker container that can run Eyesight on my local machine. My Docker knowledge is minimal at best so I'll eagerly await your repo to go public.
