2024-04-22, 16:35
2024-04-22, 17:59
what are the dimensions of the flat part?
are the many side holes punched (like real film) or just printed?
does anyone have the physical part (for scans)?
2024-04-22, 22:12
(2024-04-22, 17:59)Rene Rechthaler Wrote: [ -> ]what are the dimensions of the flat part?
I do not have the part, this is extracted data
it is 87.5 x 1187.5 LDU
Holes seem to be punched
Resolution of the PNG is only 2048 x 128
2024-04-23, 4:56
I have the part, I will look for it and will see if I can scan it, since it's transparent.
2024-04-26, 14:59
The dimensions are:
472 mm x 35 mm.
Here the scanned part. I scanned the backside. It is printed on the other side (so mirror image) based on the LEGO trademark.
Here is the print from one of the sides from the LEGO Instructions app, and here is the other side.
472 mm x 35 mm.
2024-04-27, 6:05
(2024-04-26, 14:59)Stephan den Ridder Wrote: [ -> ]The dimensions are:
472 mm x 35 mm.
A tough one... I guess it should use trans colors for everything but black, perhaps a milky white for white...
2024-04-27, 6:20
(2024-04-27, 6:05)Philippe Hurbain Wrote: [ -> ]A tough one... I guess it should use trans colors for everything but black, perhaps a milky white for white...
The white is actually pretty opaque. I can make a picture against my window with natural light coming through the part if necessary.
