Full Version: [LDPE] 1.8.77 Released (avg precision / rotation bug / triangle-to-quad conversion)
this version increases the accuracy for the calculation of the average point of the selection (affects "Move the Manipulator to the Average Point of the Selection").
It also fixes another rotation bug regarding the manipulator and corrected a minor problem with the triangle-to-quad conversion on selected objects.
[Image: imgDuke2.png]
Changelog:
(1 new feature and 2 bug fixes)
  • ...benefit from improved accuracy of "Move the Manipulator to the Average Point of the Selection".
The following critical issues are fixed:
  1. Sometimes, the 3D manipulator rotated the object instead of moving it.
  2. Sometimes, the triangle to quad conversion tool didn't use the selected triangles, but another nearby one.
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
  1. Download and extract LDPartEditor_win32_x64.zip
  2. Run LDPartEditor-1.8.77.msi
  3. Start LDPartEditor from the start menu
Installation on Linux:
  1. Download and extract LDPartEditor_linux_x64.zip
  2. Install ldparteditor_1.8.77-1_amd64.deb
  3. Start LDPartEditor from the menu or via launcher
Installation on Mac OS X:
  1. Download and extract LDPartEditor_mac_x64.zip
  2. Mount LDPartEditor-1.8.77.dmg
  3. Drag LDPartEditor.app to the Applications folder
  4. Copy ldparteditor.sh to your home folder
        4a. Open a Terminal.app and run ./ldparteditor.sh
        4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
System Requirements:
Minimum System Requirements:
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 150 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10,11, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 500 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on an SSD.
Thanks a lot, Nils!
I want to move a set of primitives to a selected vertex, using Move selected Subfile to Manipulator
As it is now , I have to move them one by one.
And when I move them like this, they loose thier rotation. All negative values are made positive.
If I select these, one by one:
1 0 -7.70209 29.6 -10 0 0 -1.34 1.34 0 0 0 1 0 1-4chrd.dat
1 0 -7.70209 29.6 -10 0 0 1.34 -1.34 0 0 0 1 0 1-4chrd.dat
1 0 -7.70209 29.6 -10 0 0 -1.34 -1.34 0 0 0 1 0 1-4chrd.dat
I get this, after they are moved:
1 0 9.86791 8.6 -10 0 0 1.34 1.34 0 0 0 1 0 1-4chrd.dat
(2024-04-01, 7:46)Magnus Forsberg Wrote: [ -> ]I want to move a set of primitives to a selected vertex, using Move selected Subfile to Manipulator
edit: This is now solved with version 1.8.78!
Thanks, Magnus. I created an issue (#1028).
Currently, "Move selected Subfile to Manipulator" does not only move the subfile, it also copies the orientation of the manipulator to it. This can't be applied to a set of primitives, which may have all distinct orientations and scales.
I see this as a problem.
After I have rounded off a vertex to a defined number of decimals, the "error message" is not rounded off.
And when I later try to attach something to that vertex it inherits the unrounded value of  the "stored" vertex.
[attachment=11572]
(2024-05-25, 14:11)Magnus Forsberg Wrote: [ -> ]I see this as a problem.
Thanks, Magnus. I created an issue (#1032), it will be solved in the next release.
