Full Version: Lsynth and windows 11
Hello,
I really need help from the Jedi of this forum. I recently bought a new computer with windows 11 so I downloaded the package with all the files and install them with no problem... BUT.. even if MLCad works fine the LSynth commands are gray and the parts are missing from the library?!
Of course I changed the path to Lsynth in MLCad.ini, scan the library many times, try to install the program again, de-activated the antivirus but nothing worked.
Does it happened to anybody else, do you gents have any idea what the problem is or coming from?
Thanks for your help.
(2024-03-22, 12:57)Baronsat Wrote: [ -> ]Hello,
Did you use the Additional-Tools-Installer (ATI):
https://www.ldraw.org/files/aioi/LDraw_A...bit_v1.exe
(2024-03-24, 11:02)Willy Tschager Wrote: [ -> ]Did you use the Additional-Tools-Installer (ATI):
Yes I did that since the begining...
but for unknown reason your answer made me found what the problem came from and it was from MLCad. ini!
I previously changed the path to LSynth without success and solved the problem by downloading a new file on http://www.holly-wood.it/
Don't ask me what the path in my mind was but it worked.
So thanks a lot.
Glad it worked! 😉
(2024-04-05, 15:40)Philippe Hurbain Wrote: [ -> ]Glad it worked! 😉
Me too I was really wondering what to do. Thanks to you two guys.
what if i got noiminated
