2024-03-15, 17:37
Hey,
this release finally fixes the annoying bug regarding rotations with the manipulator.
Thanks to Philo and Fredrik I was able to find all the root causes for this.
Changelog:
(2 new features and 1 bug fix)
The following critical issue is fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...be warned about "slashes" in subfile references and you can "Quick Fix" it.
- ..."Exclude Unmatched Edges" by default in Edger2.
- The 3D manipulator orientation got polluted during rotation.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.76.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.76-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.76.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 150 MB
- Operating System (64bit): Windows 7,8,10,11, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 500 MB
