2024-02-04, 16:35
Hey,
this release fixes the bug regarding "Save" for newly created drafts.
It also introduced a little help "?" icon which will display a reference card (cheat sheet) for some of the very basic actions needed to use the program.
I am planning to extend this cheat sheet to cover more advanced topics, too.
Changelog:
(5 new features and 3 bug fixes)
The following critical issues are fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...export a reference card (cheat sheet) for LDPE ("?" button).
- ...lock the protractor angle between the opposite and adjacent side.
- ...use the OpenGL 3.3 renderer on AMD graphic cards.
- ...inrease/decrease the font size of the text editor (with Ctrl+ and Ctrl-).
- ...benefit from the fact that the manipulator position between 3D views is synchronised now for CSG manipulations.
- Drafts can't be saved under their original filename.
- [OpenGL 3.3] Selected vertices stay hidden behind surfaces (uncritical)
- The "Smooth Vertices" action had swapped labels for "Iterations:" and "Factor:".
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.75.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.75-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.75.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 150 MB
- Operating System (64bit): Windows 7,8,10,11, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 500 MB
