2024-01-07, 13:22
2024-01-07, 20:59
Here is a raw dat file without pattern from Lego Instructions App
2024-01-07, 21:40
(2024-01-07, 20:59)Vincent Messenet Wrote: [ -> ]Here is a raw dat file without pattern from Lego Instructions App
thanks
how can extract dat file from app?
2024-01-07, 21:44
which is the lego application app lego builder?
Its a uknow world this 3d file
2024-01-08, 10:24
CLeaned and patterned
https://library.ldraw.org/tracker/33882
2024-01-08, 19:03
(2024-01-08, 10:24)Gerald Lasser Wrote: [ -> ]CLeaned and patterned
with the patterned i receive an error
i import
1410p01.dat
/s
1410p01s01.dat
1410s01.dat
1410s02.dat
i receive error 1410s01.dat not found
2024-01-09, 10:57
Are you sure you downloaded all the files, works fine for me in PD
2024-01-09, 11:50
(2024-01-09, 10:57)Gerald Lasser Wrote: [ -> ]Are you sure you downloaded all the files, works fine for me in PD
i think yes... i try several time to understand the problem...but i receive error on the s/1410s02 that should be the second png..
i have the raw file with decal that works... but i would understand if i made some error.
2024-01-09, 15:10
If you downloaded files after PartDesigner complained about them, you need to quit and restart PD. It’s because PartDesigner caches the contents of folders it has already opened: it didn’t found the file there, so it won’t look again in this session.
