2023-10-07, 13:39
this release gives you a new keyboard shortcut and fixes some bugs (thanks to Magnus and Willy!).
Changelog:
(5 new features and 2 bug fixes)
The following critical issues are fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...use a shortcut for "Merge to Nearest Vertex" (Ctrl+N).
- ...see a hint for wrong comment lines with just one slash (with quick-fix option).
- ...benefit from the fact that running a tool in the "3D Editor" will update the "Text Editor" immediately.
- ...see additional hints for the pivot point in the "Rotate" and "Scale" dialog.
- ...set the filesize limit for the !DATA meta command (in the program options).
- Pasting something via clipboard did not deselect the currently selected vertex.
- A direct colour is not an invalid number (when it contains the letter "E").
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.72.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.72-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.72.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 150 MB
- Operating System (64bit): Windows 7,8,10,11, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 500 MB
