Full Version: We have a problem, again
Remember adapting 41750 to the shape of 61678 ?
It turns out that the problem is even bigger. The Porsche slope has to fit too.
[attachment=9891]
[attachment=9892]
The grey are adapted to fit under the trans slope, and the yellow are adapted to fit the trans yellow, but these 2 groups should have the same slope shape.
I think we shall check the raw parts from the BI app...
But wasn't the Porsche slope adapted to 61678?
(2023-09-11, 20:13)Gerald Lasser Wrote: [ -> ]I think we shall check the raw parts from the BI app...
Evert-Jan Boer is working on it. Who has some fresh BI data?
(2025-04-05, 8:43)Willy Tschager Wrote: [ -> ]Evert-Jan Boer is working on it. Who has some fresh BI data?
Get me a list of design-IDs I will get you the raw data
Attached the files, scaled and centered to match the ldraw parts; part 61678 is 11153 on BIA.
(2025-04-05, 18:48)Javier Orquera Wrote: [ -> ]Attached the files, scaled and centered to match the ldraw parts; part 61678 is 11153 on BIA.
This sums-up the problem pretty well:
https://forums.ldraw.org/thread-23953-po...l#pid36418
Affected are:
42022 - https://library.ldraw.org/parts/8218
93606 - https://library.ldraw.org/parts/13997
77182 - https://library.ldraw.org/parts/26315
61678 - https://library.ldraw.org/parts/11107
44126 - https://library.ldraw.org/parts/8672
41750 - https://library.ldraw.org/parts/8015
This involves a ton of patterned parts and sticker shortcuts. Looking at the sheer number of parts, I wonder if we should overhaul them all for the shape of a curve which has no impact on the building experience itself. Speaking for myself, I can live with that ;-)
I'm fine with you fixing the top curve of 46413 and 42022 (as it doesn't involve too man parts), but let's keep the underside untouched.
