2023-08-19, 18:47
Hey,
thanks to Willy's feedback, this release fixes a few bugs.
I also did some minor work by removing the already disabled log file upload feature and improved a few unimportant points regarding pearlescent materials.
On older versions there was a bug, which led to a configuration reset when the user added a special colour to the palette and restarted LDPE (e.g. chrome, rubber, metal, ...).
Changelog:
(3 new features and 5 bug fixes)
The following critical issues are fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...show the error logfiles only ("Tools..." -> "Show Error Logs"). I removed and disabled the upload feature.
- ...get no error log entry for the case when a file could not be downloaded for part review from library.ldraw.org (there is still an error dialog, when this happens).
- ...get a better renderer result for pearlescent material with the new OpenGL 3.3 renderer pipeline.
- "Replace all" did not work in the text editor.
- Changing the colour palette in the text editor disabled the "More..." colour button.
- It was not possible to save special colours to the custom palette (e.g. CHROME, RUBBER, METAL, ...)
- The feature which checked the part file header for hints had hiccups (uncritical).
- A saved part file was not closed when the user wanted to open or create a new project and decided not keep the current files and views open.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.70.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.70-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.70.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- Operating System (64bit): Windows 7,8,10,11, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
