2023-08-06, 2:48
2023-08-08, 6:08
1. When going to https://library.ldraw.org/dashboard I get a 500 Server error page
2. Is it normal that as a regular user I can see the admin dashboard?
2023-08-08, 8:38
I have also asked about the Admin Dashboard, Orion said that is only the short version of the admin dashboard to see the parts to delete...
The link in 1. (and my own direct link) also got me a server error.
2023-08-08, 13:14
(2023-08-08, 6:08)Vincent Messenet Wrote: [ -> ]1. When going to https://library.ldraw.org/dashboard I get a 500 Server error page
1 - Bug confirmed and located. It may be a few days until it gets fixed. I have an overhaul of this page in mind so I may fold the bugfix into that.
2 - Rene is correct. There are other tabs you can see with the correct permssions. Most users should currently only be able to see the list of parts flagged for deletion.
2023-08-08, 19:23
(2023-08-08, 13:14)Orion Pobursky Wrote: [ -> ]There are other tabs you can see with the correct permssions. Most users should currently only be able to see the list of parts flagged for deletion.
OK thanks for the reply, indeed I see the parts flagged for deletion as intended then as well as the list of prims remaining with CC BY 2.0 license
2023-08-08, 22:24
(2023-08-08, 19:23)Vincent Messenet Wrote: [ -> ]OK thanks for the reply, indeed I see the parts flagged for deletion as intended then as well as the list of prims remaining with CC BY 2.0 license
I forgot I added that. That's an incomplete list as it is limited to the first 100.
2023-08-24, 2:58
This bug is fixed.
