2023-06-04, 20:54
Hey,
this version provides a "lock" button in the 3D editor to lock the rotation of the view.
It also adds some formatting to the "Name:" and "Author:" lines in the text editor.
Side notes:
I am currently learning the Rust programming language and the Vulkan API.
Changelog:
(2 new features and 1 bug fix)
The following critical issue is fixed:
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Side notes:
Changelog:
- ...lock/unlock the viewport rotation.
- ...see "Author:" and "Name:" formatted as bold and italic in the text editor.
- The "Browse..." button for the Background Picture path opened a dialog to "save" the image instead of "open".
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.68.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.68-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.68.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
