I would like to submit the 60 tooth turntable, but the newer mould of it which has only straight teeth like a spur gear rather than bevelled teeth.
Here is more info:Ā
https://brickset.com/parts/6413529/upper...e-z60-no-2
Regards, Snipe
edit: oops I meant request not submit š¤I think faster than I can type.
Raw data for this part is available in Lego instructions app. This must be cleaned by an author before it can be uploaded on the PT.
Then about Studio be aware that Bricklink consider both 18938 and 88738 parts as the same one:Ā
https://www.bricklink.com/v2/catalog/cat...=18938#T=C so it won't be added to Studio before Bricklink consider both parts as different.
(2023-12-23, 17:29)VincentĀ Messenet Wrote: [ -> ]Raw data for this part is available in Lego instructions app. This must be cleaned by an author before it can be uploaded on the PT.
Then about Studio be aware that Bricklink consider both 18938 and 88738 parts as the same one:Ā https://www.bricklink.com/v2/catalog/cat...=18938#T=C so it won't be added to Studio before Bricklink consider both parts as different.
Thanks for the raw file, Vincent. I checked in Part Designer and it looks pretty good except the round parts look edgy. I guess someone has to convince Bricklink Admins that this is not just a mold variation, but a new type of turntable since the bevel gear part was completely removed and the teeth geometry is also different (thicker tooth root and larger width).
But I would be more than happy never the less just to import it as a custom part to Studio.
![[Image: U1KCQjB.png]](https://i.imgur.com/U1KCQjB.png)
