Full Version: [LDPE] 1.8.67 Released (scientific num. / bugfix: manipulator pos/ library.ldraw.org)
this release adds hints when using the scientific number format.
It corrects a 3D manipulator bug and five other issues.
The download of data from library.ldraw.org works now!
[Image: attachment.php?aid=12753]
Changelog:
(1 new feature and 6 bug fixes)
  • ...see a hint on numbers with scientific notation (you can also "quick fix" these numbers).
  1. The 3D manipulator orientation got polluted.
  2. LDPE was not able to download from library.ldraw.org
  3. The tabs in the 3D editor couldn't be moved around. The text editor was not affected.
  4. SymSplitter cutted with data from subfiles too, in addition to the cutting plane (see images on https://github.com/nilsschmidt1337/ldpar...issues/959 )
  5. Intersector calculated sometimes wrong results with some triangles missing.
  6. It was not possible to do a "copy + transform" action on MacOS X with the cursor keys (see https://github.com/nilsschmidt1337/ldpar...issues/958 ).
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
  1. Download and extract LDPartEditor_win32_x64.zip
  2. Run LDPartEditor-1.8.67.msi
  3. Start LDPartEditor from the start menu
Installation on Linux:
  1. Download and extract LDPartEditor_linux_x64.zip
  2. Install ldparteditor_1.8.67-1_amd64.deb
  3. Start LDPartEditor from the menu or via launcher
Installation on Mac OS X:
  1. Download and extract LDPartEditor_mac_x64.zip
  2. Mount LDPartEditor-1.8.67.dmg
  3. Drag LDPartEditor.app to the Applications folder
  4. Copy ldparteditor.sh to your home folder
        4a. Open a Terminal.app and run ./ldparteditor.sh
        4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
System Requirements:
Minimum System Requirements:
  • Operating System (64-bit): Windows [7 or newer], Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • RAM: 4GB
  • Video-Memory: 1 GB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7,8,10, Linux [e.g. Ubuntu Linux >=14.4], Mac OS X [>=10.6]
  • OpenGL 3.3 compatible Graphics Card
  • RAM: >4 GB
  • Video-Memory: >1 GB
  • Free Disk Space: 512 MB
  • For a faster start, LDPartEditor and the LDraw™ library should be installed on an SSD.
Part review from the menu works again! Thansk!
This code, from https://library.ldraw.org/tracker/31251,  gives a rather confusing error message.
[attachment=9664]
The "error" here is that I don't (yet) have r04i1000.dat in the right folder
I sometimes still get this error. Think it was fixed earlier.
[attachment=9665]
(2023-05-18, 7:58)Magnus Forsberg Wrote: [ -> ]This code, from https://library.ldraw.org/tracker/31251,  gives a rather confusing error message.
Thanks, Magnus. I created an issue (#967).
(2023-05-18, 9:34)Magnus Forsberg Wrote: [ -> ]I sometimes still get this error. Think it was fixed earlier.
Unfortunately, it was not fixed completely. I invested not enough time to find a perfect solution.
