2023-03-15, 18:55
Hey,
this version will extend the "change winding"-tool to work with lines and condlines, too.
It also corrects a "Merge to Nearest Vertex" bug. This merge function will now skip pure condline control points.
There was an important change on the LDraw library URL, too (www.ldraw.org -> library.ldraw.org).
![[Image: attachment.php?aid=12753]](https://forums.ldraw.org/attachment.php?aid=12753)
Changelog:
(4 new features and 3 bug fixes)
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...use the change winding tool (j) on type 2 and type 5 lines, swapping the end points.
- ...have the "verbose" option common to nearly all tools, and be remembered between sessions.
- ...deep inline a subfile and it will mark the end of that subfile, too.
- ...have the CR LF at the end of a line to be included in the selection when you click on a line number.
- "Merge To Nearest Vertex" recognized condline control points as vertices to merge for.
- The LDraw library URL was outdated (www.ldraw.org -> library.ldraw.org).
- 3D scenes only rendered to 1/4 of 3D window in some rare cases.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.66.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.66-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.66.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
