Hello, since the digital instructions are out today, I want to build the Rivendell set digitally.
But there are some pieces missing (no critical ones):
https://www.newelementary.com/2023/02/le...rings.html)
- Plant, w/Plate 2x3x2, No. 1 (Design ID 2682)
- lotsa new Weapons (Axe, Swords, Sting, broken Narsil)
- new headgear and wigs (Gimli Helmet 2675 and Beard 2676, Legolas/Elrond Hair 100953, dual molded, like 10055p01)
- new Heads and Torsos
Edit: not new but still missing: 36806
https://www.bricklink.com/v2/catalog/cat...conly%22:0}
80497 is very similar to 43892, but still new
I think I will just build the base without the figures to add them later.
hopefully they will add the 3D files for the instructions app, so far only the PDF instructions are available
(2023-03-05, 21:17)Gerald Lasser Wrote: [ -> ]hopefully they will add the 3D files for the instructions app, so far only the PDF instructions are available
Hello Gerald,
Can you give us some informations to get this famous 3D files ?
I found some files __data inside the app folder, is it a unity 3D file ?
Thanks in advance
(2023-03-13, 7:59)Faramond Florent Wrote: [ -> ]Hello Gerald,
Thanks in advance
Correct, however among the different LEGO apps, there is no common directory, so it is a bit of a hunt for each app (Instructiosn/catalogue) where the files are finally. For the instructions app, they can be found unter /files/UnityCache/Shared there are files which have the Design-ID in their filename. You can view/export them with a Unity Browser, e.g. Asset Studio.
Most exports unfortunately miss all the standard studs and tubes.
(2023-03-13, 10:22)Gerald Lasser Wrote: [ -> ]Correct, however among the different LEGO apps, there is no common directory, so it is a bit of a hunt for each app (Instructiosn/catalogue) where the files are finally. For the instructions app, they can be found unter /files/UnityCache/Shared there are files which have the Design-ID in their filename. You can view/export them with a Unity Browser, e.g. Asset Studio.
Perfect ! It works perfectly. Thanks a lot.
Here you are the part 36806 in raw version extract from the app.
(2023-03-13, 21:07)Faramond Florent Wrote: [ -> ]Here you are the part 36806 in raw version extract from the app.
This is not usable, to convert to ldraw standards. It is not sized correctly, and the mesh is way to high in resolution.
There is a tool in LDPE called MeshReducer, but I have never used it. How does it work?
There doesn't seem to be any settings I can use to control the result.
What would be the best way here? Resize first, and then reduce, or start by reducing the mesh?
(2023-03-14, 16:26)Magnus Forsberg Wrote: [ -> ]This is not usable, to convert to ldraw standards. It is not sized correctly, and the mesh is way to high in resolution.
36806 is also available from digital-bricks.
The data from the catalogue app is sometimes very very detailed and difficult to reduce.
BTW: I got the new plants on my table!
Here you are the part 80497 in raw version extract from the app.
(2023-03-15, 21:36)Faramond Florent Wrote: [ -> ]Here you are the part 80497 in raw version extract from the app.
That is an other alias of 43892 there is already 28959
Edit: Sorry, saw on BL that this is actually a different mould, we should get it from the instructions
I'm working on 76959 also !
Hello, finished the first part:
attachment=9440]
built and rendered in Studio, red=wrong part, didnt use the new parts yet.
(2023-03-30, 19:55)Rene Rechthaler Wrote: [ -> ]Hello, finished the first part:
On my side, I finished it few days ago
But I have to update with the new parts from Philo.
attachment=9441]
(2023-03-30, 20:04)Florent Faramond Wrote: [ -> ]On my side, I finished it few days ago
I can't find item 15210 on Studio
where did you find it?
(2023-04-07, 13:46)Natalie Schauw Wrote: [ -> ]I can't find item 15210 on Studio
Hello Natalie,
You have to import the part from LDraw (
here) with Studio Part Designer.
Awesome Philo!
https://library.ldraw.org/tracker/31197
Can you explain me how you can get the original part shape from LEGO Instructions App ? You talk about "LEGO Builder" app or "Catalogue en 3D" ?
Liebe, Philo Hurbain!!
1 Rally Reifen Reifen 81 x 29 Teile 2491 kaputt
2 Klaue 2 x 12 x 9 Teile 2502 kaputt
3 Balkenrahmen 5 x 15 mit 3 Fachwerkstangen Teile 79767 kaputt
4 Balkenrahmen 7 x 15 mit 3 Fachwerkstangen Teile 79766 kaputt
5 Lenkradnabenhalter mit 2 Kugelgelenken & 2 Achslöchern Teile 100943 kaputt
6 Lenkung / CV Kugelgelenk Buchse 2L Teile 4192 kaputt
7 Hubarm Modifizierter Träger Dreieckig Dick 7 x 16 Teile 79768 kaputt
8 Schalthebel mit Nutteilen 4158 kaputt
9 Schaltgabel Teile 4159 kaputt
10 Mitnehmerring 2L Teile 2473 kaputt
11 Schneckengetriebe 6M mit Achslochteilen 73763 kaputt
12 Brick Special 2 x 2 x 1 2/3 mit Schneckengetriebe Lochteile 73764 kaputt
13 Gang Schrittmotor mit 8 Zähnen Teile 2474 kaputt
14 Rad 49.5 Mars Rover mit flachen silbernen Speichen Muster Teile 100942pat0001
Lego Parts ist reißt kaputt!!
Viele Danke!!
14 Rad 49.5 Mars Rover mit flachen silbernen Speichen Muster Teile 100942pat0001 kaputt
Viele Danke!!
