2023-02-24, 19:49
Hey,
this release will provide four small improvements.
Changelog:
(4 new features)
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
(4 new features)
- ...benefit from a new Rectifier default setting (it will not convert quad to rect when the quad has adjacent condlines by default (results in smoother surfaces)).
- ...use the "Copy" command on the icon bar at the bottom of the tab, mirrored from the contextual of the "Problems" tab
- ...have a single background bounding rectangle for the whole string (txt2dat).
- ...use an alternative option to not have a background but only the characters themselves (txt2dat).
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.64.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.64-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.64.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
