2023-02-05, 13:18
Greetings!
Requesting these parts commonly used in any sets of the Mars Mission theme:
58844 Torso/Head Martian With Chest Hole
58845 Leg Martian Rounded
59492 Projectile Launcher, Foam Dart Launcher, Four Barrel
58947 Cylinder 9x4x2 Tapered with Flat bottom, Pinholes / "Tube End"
58843 Martian Hypersled with Pin (Mars Mission)
62723 Torso/Head Martian With Chest Hole, Alien Commander (don't know if that's its exact number)
62724 Arm/Leg Mechanical, Alien
It seems the first four parts listed are available as a raw LCad 3D model, which I needed most for the moment. The other parts aren't even in the digital-bricks list though. If anyone knows any place where I can at least find their 3D models it'd be most appreciated.
I am currently working on a project about the 2007-2008 theme Mars Mission. Building the Models for later use in Blender has been done with Bricklink's Stud.io 2 so far when I have learned that a lot of iconic Mars Mission parts where missing in their library. It's weird how these parts are nonexistent in any part libraries I have found so far. Then after some research I found out that it's technically you guys running the entirety of digital LEGO building with your parts library. No matter if some Mars Mission parts are missing: Thank you, you're awesome.
