2023-02-01, 4:33
I was trying to create a custom sloped brick in Studio, and I wanted to get a Collada mesh so I could render it properly with the bumpy slope texture. I used Studio's own Collada exporter, but as you can see I got some wrong results.
[attachment=9137]
On the left is a normal slope brick; on the right is my custom subpart. You can see that it's Z-up rather than Y-up, so I guess the export is set for Blender, and it may also be inside-out. The sloped surface itself is oriented correctly because it's the same one Studio uses; only the subpart is different.
There are export settings for both winding and handedness that I could mess with, but I wonder if there's a quick way to just swap the axes? Or a better way to get the Collada mesh of an LDraw part than going through Studio?
[attachment=9137]
