I need to generate milions of Lego visualizations.
I know more or less how to generate ldraw files programmatically.
How can I programmatically generate visualizations?
I would like to be able to:
- Change camera position
- change textures
- change lighting
-change background
- add some noise objects
Any idea?
(2022-12-18, 8:10)Willy Tschager Wrote: [ -> ]http://www.holly-wood.it/ldview-en.html
LDView is takind the snapshots
However, it seems to ignore -DefaultLatLong and -DefaultMatrix command line options.
I am using Linux Version 4.4.1 Do Yoiu know how to make it work?
(2022-12-20, 16:33)Jerzy Orłowski Wrote: [ -> ]LDView is takind the snapshots
Here's some more guidance on those 2 commands:
https://trevorsandy.github.io/lpub3d/ass...aultMatrix
Note that -DefaultLatLong overrides -DefaultMatrix on the command line.
Also, since these are string values you might try putting them in quotes.
(2022-12-20, 17:45)Orion Pobursky Wrote: [ -> ]Here's some more guidance on those 2 commands:
There is a locale-related bug in the Qt version of LDView, where it interprets the comma in -DefaultLatLong as a decimal separator. We think we found a workaround until a new release can fix it for real.
