(2022-11-19, 4:45)Orion Pobursky Wrote: [ -> ]https://www.ldraw.org/article/340
Added Moved (should have been there all along) and the approved Helper category
Clarified use for Helper, Moved, and Obsolete.
FYI, unless there is a bug in my script that I use to generate the PDF parts catalog, the following categories are not used by any official parts:
- Forklift
- Grab
- Helper
- Lever
Since Helper is new, that's I assume not unexpected. We might want to consider whether the others should be left as valid categories, though.
(2022-11-19, 8:02)Travis Cobbs Wrote: [ -> ]FYI, unless there is a bug in my script that I use to generate the PDF parts catalog, the following categories are not used by any official parts:
- Forklift
- Grab
- Helper
- Lever
I almost forgot: POV-Ray and String are used as category by at least one official part each. We obviously don't want POV-Ray (used for light.dat), but String should perhaps be added to the list. (It seems at least
conceivable that LEGO would have a string with different thickness at some point.)
I would like to have a link on that page, to use for a download of Category.txt needed by DatHeader.
The update function in DatHeader doesn't work anymore.
attachment=8689]
(2022-11-19, 8:04)Travis Cobbs Wrote: [ -> ]I almost forgot: POV-Ray and String are used as category by at least one official part each. We obviously don't want POV-Ray (used for light.dat), but String should perhaps be added to the list. (It seems at least conceivable that LEGO would have a string with different thickness at some point.)
An update to light.dat (incidentally that last part with release ORIGINAL) is on the PT. I suppose it can use the Helper category but moving it to the /h folder isn't possible just yet.
I agree with String and will add it.
I already thought of that and it's in the works.
However, I don't know the URL DATHeader is using.
- Forklift
- Grab
- Helper
- Lever
Grab can go away.
Looks like all the Forklift parts got moved to Vehicle. Maybe we should consider doing the same for the other non-Car/Plane/Boat categories (like Tractor and Exhaust)
Lever is more useful as a category but since it's not in use it can probably go as well.
(2022-11-19, 15:01)Orion Pobursky Wrote: [ -> ]I already thought of that and it's in the works.
The same as the part tracker !
(2022-11-20, 17:05)Michael Heidemann Wrote: [ -> ]The same as the part tracker !
The PT has the list hard coded. That said, the code base is large and I didn't write it so there are sure to be things I'm not I'm not aware of. Where, specifically, is DATHeader pointing for this file.
