Hi all,
I was looking for part 46481 and found out that it was not in the library.
Searching some more I found 48172 which seems the same.
https://brickset.com/parts/design-48461
Or is there a difference?
Should we create an alias?
I have found anotherone:
Technic, Brick Modified 2 x 2 with Pin Holes and Rotation Joint Ball Half (Vertical Side)
In LDraw now 48171
The new number (?) for this part is 48454. Please add an alias for this one too?
(2022-11-21, 12:27)Jaco van der Molen Wrote: [ -> ]I have found anotherone:
In LDraw now 48171
And another
Slope, Curved 2 x 1 x 1 1/3 with Recessed Stud
What we call Brick 2 x 1 x 1 & 1/3 with Curved Top
Part 6091 has a new number too: 32807
These are both now on the PT.
(2022-11-21, 17:00)Orion Pobursky Wrote: [ -> ]These are both now on the PT.
Tnx. Can you guess what I am building? ;-)
(2022-11-22, 13:18)Jaco van der Molen Wrote: [ -> ]Can you guess what I am building? ;-)
There is a searchtool here, that could be used, if I only knew the colour on the bricks you have/use.
https://brickset.com/search/advanced
