2022-11-01, 9:16
2022-11-01, 9:26
(2022-11-01, 9:16)Star Wars R2-D2 Wrote: [ -> ]10225 R2-D2 UCS
75308 R2-D2
[attachment=8608]
This file is OMR compliant but I need help (x3) !
1 ) It's my first try to make a flexible part in LDCAD and i probably make a mistake, LDCAD produced flat part detected by LDview.
2 ) The sticker is not as good as I want. If someone have a high quality scan. Or I have to fully redraw the pattern...
3 ) Dome for the R2-D2 minifig missing. I have not the part and only a picture of the front. If someone have a picture of the back ?
[attachment=8656]
New file uploaded with flexible parts fixed, better sticker version added. LDview performed rendering without warning.
Dome always missing (BrickLink 553pb004, Rebrickable 30367cpr0006)
2022-11-01, 9:49
(2022-11-01, 9:16)Marc Giraudet Wrote: [ -> ]Star Wars R2-D2
10225 R2-D2 UCS
75308 R2-D2
75308 In progress but Jawa didnt sell all parts ...
[attachment=8609] >> [attachment=8621]
Ah, all parts are recovered except flexible parts (work in progress).
2022-11-01, 14:32
(2022-11-01, 9:26)Marc Giraudet Wrote: [ -> ]3 ) Dome for the R2-D2 minifig missing. I have not the part and only a picture of the front. If someone have a picture of the back ?
That dome is this one:
https://www.ldraw.org/cgi-bin/ptdetail.c...67cps8.dat
Edit: The above reference is incorrect
2022-11-01, 16:52
(2022-11-01, 14:32)Orion Pobursky Wrote: [ -> ]That dome is this one:
No, that's not correct. The design used in this set is not made yet.
2022-11-01, 17:41
(2022-11-01, 16:52)Magnus Forsberg Wrote: [ -> ]No, that's not correct. The design used in this set is not made yet.
Confirmed, Magnus is correct. The part I referenced above had incorrect set keywords.
2022-11-03, 20:35
(2022-11-01, 9:49)Marc Giraudet Wrote: [ -> ]75308 In progress but Jawa didnt sell all parts ...
Nice, if you want to do the plaque as well, just uploaded the sticker. Too bad the R2 minifig dome is not yet available, 30367cps8 comes close for a replacement.
2022-11-05, 13:01
(2022-11-03, 20:35)Evert-Jan Boer Wrote: [ -> ]Nice, if you want to do the plaque as well, just uploaded the sticker. Too bad the R2 minifig dome is not yet available, 30367cps8 comes close for a replacement.
Thanks for the sticker and the "lucasfilm" part. Rendering with your element.
I working on the 14301 flex part template. It took time because I want to cleary inderstued the LDCad meta in order to produce 30527 flex for 10225 R2-D2.
[attachment=8623]
2022-11-05, 17:52
[attachment=8624]
File OMR compliant
Known issue : Head of minifig R2-D2 pattern missing, unofficial parts or sticker embedded
2022-11-09, 19:06
10225 R2-D2 UCS
75308 R2-D2
8009 - R2-D2
Another model
[attachment=8638]
[attachment=8637]
File OMR compliant
Known issue : None
