2022-09-30, 21:21
this release will add five small improvements and fixes one bug regarding the "Save As..." button.
Changelog:
(5 new features and 1 bug fix)
However, something can go wrong in about 140.000 lines of code.
Installation on Windows:
System Requirements:
Minimum System Requirements:
Changelog:
- ...keep all files from the initial temporary project on application restart.
- ...see the D value (distance) of the distance meter not only shown in "LDU" but also in "mm" and "Stud".
- ...copy hint/error/warning messages to the clipboard to paste it to the PartsTracker.
- ...have a customizable line size button where you can set the thickness of the line for yourself (Ctrl+Click on a line size button).
- ...use more line size buttons (five).
- "Save as..." removed sometimes a correct directory prefix (e.g. "48\") from the file header.
- Download and extract LDPartEditor_win32_x64.zip
- Run LDPartEditor-1.8.63.msi
- Start LDPartEditor from the start menu
- Download and extract LDPartEditor_linux_x64.zip
- Install ldparteditor_1.8.63-1_amd64.deb
- Start LDPartEditor from the menu or via launcher
- Download and extract LDPartEditor_mac_x64.zip
- Mount LDPartEditor-1.8.63.dmg
- Drag LDPartEditor.app to the Applications folder
- Copy ldparteditor.sh to your home folder
4a. Open a Terminal.app and run ./ldparteditor.sh
4b. Or open a Terminal.app and run /Applications/LDPartEditor.app/Contents/MacOS/LDPartEditor
- RAM: 4GB
- Video-Memory: 1 GB
- Free Disk Space: 100 MB
- RAM: >4 GB
- Video-Memory: >1 GB
- Free Disk Space: 512 MB
