I was editing a model in LDCad and needed brick 3940b (Support 2 x 2 x 2 Stand) and so I searched for "3940".
LDCad finds 4 bricks with "3940" and then crashes.
What causes this?
Jaco
(2022-08-25, 13:41)Jaco van der Molen Wrote: [ -> ]Hi,
What causes this?
Jaco
Had the same, found the issue to be in a part I created, sorry..
Updated 19789s01, it had some triangles/quads in edge color (24) instead of 16, this causes LDCad to crash for some reason.
If you update this subfile the crash should be gone.
(2022-08-25, 15:05)Evert-Jan Boer Wrote: [ -> ]Had the same, found the issue to be in a part I created, sorry..
That should not crash anything, so it's a bug.
I fixed it in the 1.7 Beta 1 code.
(2022-08-25, 17:54)Roland Melkert Wrote: [ -> ]That should not crash anything, so it's a bug.
OK, crash is in 1.7 Alpha 2 btw.
@Roland: Since you fixed it, I suppose you do not need the log or anything
@Evert-Jan: I will replace the subfile and see if I can use either old part 3940b or the new 19789.
Needless to say perhaps, but is the correct version of 19789s01 on the partstracker for the next release ;-)
(2022-08-25, 20:07)Jaco van der Molen Wrote: [ -> ]OK, crash is in 1.7 Alpha 2 btw.
No the bug was quite obvious, it was practically visible from space
